Lot's of guys will use marvel mystery oil, a couple tablespoons down each spark plug hole. Is the motor locked up? If so, you'll have to be patient. It won't loosen up in a day or two. New fuel pump, rebuild carburetor, and use fresh gasoline. Maybe rig up a portable boat tank or something like that. Stale gasoline is bad stuff.
Well I decided and try to get the 289 running, when it stops raining (Northern Calif). I also have a 30 Ford coupe with a 350. Just order some parts from Carpenter & a catalog. Never done a Ford before, it should be fun. Need more Ford F-100 Catalogs. Where Where ???
Where in NorCal are you at? This rain is killing me too I just want to go out and drive already...
