Fuel pressure questions
Old Feb 18, 2017 | 06:13 PM
Lhornung's Avatar
Lhornung
So I recently checked fuel.pressure and found it to be running at 50 at idle and 40 at WOT throttle. I then replaced the spring and the numbers have not changed. What should I do next?
Old Feb 18, 2017 | 07:11 PM
Bubba Jones's Avatar
Bubba Jones
Well those numbers are technically acceptable. Lot's of stock pressures fall in that range.
However, if you do want to increase it, researching the BB mod should do the trick. Basically you take a normal BB and shove it behind the spring in the regulator which increases the set pressure from the regulator.
It takes like 5 minutes to do it as long as you don't drop the pieces down in the valley like I did.
Old Feb 18, 2017 | 08:01 PM
Lhornung's Avatar
Lhornung
Will the bb just cover up another problem seeing as I just did the new spring?
Old Feb 18, 2017 | 09:14 PM
oldbird1965's Avatar
oldbird1965
No, the BB mod is done by a lot of us.
Old Feb 18, 2017 | 09:37 PM
Lhornung's Avatar
Lhornung
Ok I'll have to try it when I clean my screen.
thanks for the input
Old Feb 19, 2017 | 11:35 AM
friskyjake's Avatar
friskyjake
bb & spring
Does the bb go in 1st & then the spring & then the cap? I just received my new spring { the spring that Knotyrope suggested} have not installed it yet. Maybe I don,t need the bb? Curious. The new spring is a little shorter also. Friskyjake
Old Feb 19, 2017 | 12:04 PM
fordpride's Avatar
fordpride
B.B. Goes between the spring and plunger. If fuel pressure rises above 70 remove the bb
Old Feb 20, 2017 | 07:58 AM
knottyrope's Avatar
knottyrope
spring is a small amount shorter than the stock spring but with more strength/pressure
Old Feb 24, 2017 | 08:04 PM
Lhornung's Avatar
Lhornung
Ok.so I cleaned my FOR screen and wow was if covered with crud I couldn't see how any fuel passed through it. When doing so I did the bb mod and all is well my fuel pressure at idle is 68 & @ WOT in 3rd it's 58 at absolute lowest my concern.is that when I let off the pedal it spikes to 84 then comes back down to normal is that ok?
Old Feb 24, 2017 | 10:07 PM
97-psd's Avatar
97-psd
It will spike some when you let off from wot. Sounds a touch high but should be ok. I have mine adjusted to 60 at idle. Honestly, 50 at idle and 40 and wot isn't bad. A little more wouldn't hurt but you aren't in dire need of more pressure
brian42
May 13, 2015 11:15 PM
gchan011253
Mar 9, 2011 07:33 PM
florida_1959
Oct 2, 2010 03:57 AM
Ringer97
May 16, 2008 07:02 AM
