Injectors
Old Feb 17, 2017 | 10:06 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Injectors
So im to the point i am going to replace the 1 and 3 injectors. I get a fairly constant cyl3 contribution code. Lately the cyl1 keeps popping up. I found some new not in original package ford injectors for 169.99 with out a core fee. Ive dealt with the seller before when i purchased the ipr for my truck amd the parts were new in package. They sell a large amount of oem ford parts as well. So im comfortable that the injectors will be as they are stated. Does this sound like a decent price. Keep in mind the lack of a core charge.
Old Feb 17, 2017 | 10:07 PM
Lubbockguy1979
Also is there a oring and copper washer kit avalible for individual injectors replacement?
Old Feb 18, 2017 | 07:11 AM
npccpartsman's Avatar
npccpartsman
Yes, there are individual kits available, but OEM injectors come with O-rings and copper washers already installed. That's a crazy cheap price for Motorcraft injectors, BTW, and there are core buyers that will give you a decent price for your cores.
Old Feb 18, 2017 | 08:16 AM
navistarnut's Avatar
navistarnut
My only concern would be if the o-rings were at all brittle since not in any packaging depending on the age. I've seen new parts that sat on the shelf for 10 years that had brittle soft parts. One pump for a tractor comes to mind when I was at a implement dealership. Problem was easily remedied with two new o-rings.
Even if that is the case here the Alliant kits are cheap enough and it's still a good deal.
Old Feb 18, 2017 | 11:49 AM
FiznUKa's Avatar
FiznUKa
Here's is a Ford reman injector if you have a question on what to look for. It should have the reman stamp on it.
Old Feb 18, 2017 | 03:58 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Alliant 6.0L Injector O-rings 03-07 - Riffraff Diesel Performance
Motorcraft 6.0L Injector O-rings 03-07 - Riffraff Diesel Performance
Old Feb 18, 2017 | 06:54 PM
Lubbockguy1979
Thanks ttu
Old Feb 18, 2017 | 07:06 PM
Lubbockguy1979
It appears to have them in the pic. I would rather be prepped though. When im working on a truck is usually at the tail end of when auto zoo is open and since im not working on a sbc parts are scarse on the weekend
TJ Dykstra
13
Apr 13, 2018 09:25 AM
Jaaaaaaackman
25
May 22, 2011 09:28 AM
xgatorx1976
Apr 22, 2008 09:11 PM
paradiseandpalms
16
Nov 7, 2006 03:53 AM
4x4k20
Jan 29, 2005 09:48 PM
