Need some help 7.3l
Old Feb 16, 2017 | 07:08 PM
texbigred1's Avatar
texbigred1
Need some help 7.3l
I have a 02 f250 4x4 7.3l. I drove it all weekend and no problems. It sat till yesterday I got in it to go to church. It started up and had a little miss was around 60 f. Then the od light started flashing. Not in any code just constant flash. I was parked down in my drive way. It idled fine but acted like it wouldn't take fuel. So looked around and found the hose on the map sensor was broke. So today I fixed the hose. Checked the oil level and battery connections. Still running weird and flashing od light. I got under the hood and wiggled plugs I unplugged the ice. It reved up then back down and started running smoothly. Got in it and it backed out of the drive way. It ran and drove fine. What I need to know is why??? The ice is a new one from Ford. Anybody have any ideas. I'm all ears
Old Feb 16, 2017 | 08:41 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
If it runs rough with the ICP plugged in, and it runs well after unplugging the ICP...that points to the ICP being bad most of the time. Is there any oil in the connector when you unplug it?
Of course, that does not account for the flashing OD light. That is telling you there is a transmission issue. Pull codes and post them here for correct advice on what to do next with that.
Old Feb 16, 2017 | 09:18 PM
5_labsownus's Avatar
5_labsownus
Most likely a flashing OD light is a wheel or transmission speed sensor but an ABS/brake issue can cause the light to flash. This can affect shifts, power, ABS and if equipped traction control including automatic 4wd. The ECM/IDM see a problem it does not know what to do with and puts in in to a safe mode so to speak. That is a very rudimentary definition.
Rod
Old Feb 17, 2017 | 06:57 AM
texbigred1's Avatar
texbigred1
The icp is a new Ford one. I replaced it 3 months ago for the oil leaking out of the plug. Hope it's not bad but possible. When I unplugged it, it made the engine Rev up some. Maybe 500 rims then right back down. Like it reset the computer. I do know that my od light has a short in it and I have a new one. Just haven't been able to install yet. I'll pull the codes to ight and see what they areally and report
Old Feb 17, 2017 | 08:32 AM
Rikster-7700's Avatar
Rikster-7700
Have you checked and cleaned the pigtail connector to make sure it's making good contact?
Old Feb 19, 2017 | 12:35 PM
texbigred1's Avatar
texbigred1
which pig tail. I cleaned most under the hood even idm and pcm. Just replaced the shifter it had a bad spot in it and the od light would stay on. I had the battery's unhooked for 2 hrs. Just started it up and od light is flashing . Has codes
p0755
p0743
p1754
p1747
all trans codes. I'm going to check the plugs on it now see if there's a problem the the trans only has 3000 miles on it.
Old Feb 19, 2017 | 01:30 PM
Rikster-7700
On the ICP pigtail that was covered in oil. There is something going on with your ICP sensor if you unplugged it and things cleared up. Just trying to find obvious and cheap solutions first
Old Feb 19, 2017 | 01:53 PM
texbigred1's Avatar
texbigred1
Icp pigtail is clean. I cleaned the trans plug it has trans fluid in it. Might need an orings behind shift sensor. I cleaned it fired it up and ran like a champ. Got another check engine light. Now says codes in idm. I'll have to get a better scanner to see what codes are in it. I'm about ready to sale this truck. Had it 6 months and put over 3gs in it to keep it on the road. I think valve cover gaskets are next
Old Feb 21, 2017 | 12:24 PM
texbigred1's Avatar
texbigred1
Can a loose uvch cause the trans codes? I'm going to look it to that next. SometI messed it runs great others not so much so I'm thinking one maybe loose. Any ideas??
Old Feb 21, 2017 | 11:17 PM
HKusp's Avatar
HKusp
Stop guessing and get the codes read by a shop that ha the ability to read our trucks. The parts stores don't have the right equipment, as our trucks are non-obdII compliant.
Old Feb 23, 2017 | 05:37 PM
texbigred1's Avatar
texbigred1
Driver side
Opened up the driver side found this when I had the injector Balance test done it came back good on all.
Old Feb 23, 2017 | 06:41 PM
Big Black Dually's Avatar
Big Black Dually
I just had a similar problem.
My OD light was flashing about a month or so earlier and my truck would run rough like it was starving for fuel. I changed out the TSS and the OSS sensors and the transmission smoothed out and the truck ran so much better.
It was an adventure to change the TSS and the OSS.
Then it started flashing again but it ran okay. This time
I had a bad neutral safety switch and that pigtail was bad. It caused my OD light to flash. The sensor in this picture was a ford part, that failed in only 15 months.
BBD
Sara Byrd
Mar 15, 2025 08:06 PM
derekmj64
May 28, 2012 08:01 AM
jimandjimmer
Sep 12, 2009 07:23 AM
Tarpon1
1978 - 1996 Big Bronco
Apr 29, 2008 02:40 PM
rbengl
Feb 7, 2008 11:42 AM
