E4OD Acting up
Old Feb 16, 2017 | 12:17 AM
RJ sheedy's Avatar
RJ sheedy
E4OD Acting up
Welp guys. Back on the threads as im havin trouble sellin my truck. So heres what this ones about. My 92 f-350 4x4s trannys been actin weird lately Sometimes it kicks hard from 1st to 2nd. P.O told me it was because of a shift kit he had put in BUT sometimes it does not kick that hard and i can barely feel the shift Trans fluid looks and smells fine The trans is apprently leaking from somewhere i havent found out where Anyone know what could be causin this ?
Old Feb 16, 2017 | 08:06 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's pretty hard tell where it is leaking from without seeing the trans in person and NO description from you. My best guess is it's leaking from somewhere under the truck.
Old Feb 16, 2017 | 08:25 AM
RJ sheedy's Avatar
RJ sheedy
let me clarify. Im not asking where its leaking from. Im asking if anyone knows of any COMMON leak spots Like iv heard from multiple people the main seal tends to leak when it gets hot
Old Feb 16, 2017 | 11:01 AM
TheGreat460's Avatar
TheGreat460
Theres a line that runs from the transmission up into the cooler. I'm not sure if the line is going to the cooler or not that's just what I assumed. But theres a small pipe on that line with two clamps on it. My truck is a bit leaky from that pipe. also the transmission fluid pan can get a bit leaky as well. To find that pipe just follow the lines on the trans up under the engine.
Old Feb 16, 2017 | 11:04 AM
RJ sheedy's Avatar
RJ sheedy
I think i know what your talking about. I replaced a rubber hose in the middle of one of those lines but ill have to look into it more. As for the trans pan that may be what the main leaks coming from actually. Its not much not enough to make noticable drip spots but You can tell its leaking
MikeSDK
Aug 26, 2017 09:35 AM
DougJ_1997PSD
Apr 24, 2015 05:56 PM
The Blue mule
May 6, 2012 06:32 PM
5X5MOOSE
Jul 30, 2009 06:15 AM
