Trans Leak
Old Apr 20, 2015 | 09:47 PM
DougJ_1997PSD's Avatar
DougJ_1997PSD
Trans Leak
It seems that my E4OD transmission is leaking a bit of fluid at the cooler line input. I just had it rebuild about 15k ago. I took it in to the shop about 6 months ago and they said they fixed the cooler line because there was a small leak. Now that the warranty is up, I need to fix this myself. I'm an engine guy not a trans guy and don't want to mess up the lines at all, so what is the best way to fix the leak?
Old Apr 21, 2015 | 09:13 AM
fordpride's Avatar
fordpride
Is it leaking athe the line to fitting or fitting to trans ?
Old Apr 21, 2015 | 08:18 PM
DougJ_1997PSD
not 100% sure right now. i'll clean it tomorrow and let you know.
Old Apr 23, 2015 | 01:00 PM
DougJ_1997PSD
sorry about the delayed response! i have been very busy the past few days. it seems that the leak is coming from where the line meets the fitting. do i need to replace the whole line?? i also checked the fluid and even after driving ~10 miles it was in the middle of the cold level, so im thinking it is about .5-1 quart low. could the line leak that much in 2 or 3 weeks?
Old Apr 23, 2015 | 01:12 PM
fordpride's Avatar
fordpride
Have you tried to tighten it
Old Apr 23, 2015 | 02:26 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That line flows a gallon per minute. If it were wide open you'd lose a gallon per minute. If it didn't leak at all you'd lose nothing. Your leak is somewhere in between. Could that mean a quart in a week? Of course.
Is your leak big enough to leak that much? I'm staring into my crystal ball, but the picture is fuzzy. Maybe if you put a bright light under the truck I could see it better.
Old Apr 24, 2015 | 08:49 AM
quesey's Avatar
quesey
May want to pull the line lose an replace the oring in there. I built a trans once an forgot to install those rings an leaked some but not full flow.
Old Apr 24, 2015 | 05:56 PM
DougJ_1997PSD
I'm out of town this weekend so I'll get pictures and such when I get back. I had the transmission rebuilt at a reputable shop, and they said that they fixed a small leak by tightening it about 6 months ago. I haven't seen a leak until about 2 weeks ago and I crawl under my truck often. I dont think the o-rings would have gone bad this fast.
walmill
Jul 11, 2018 08:40 PM
96_Powerstroke
Nov 7, 2015 10:10 PM
73fxe
1997 - 2003 F150
May 4, 2015 12:51 AM
BBslider001
19
Jan 27, 2014 11:21 AM
GeoffNJ
Mar 2, 2006 02:49 PM
