Bronco II Ford Bronco II
1990 2.9 problems
Old Feb 14, 2017 | 07:53 PM
97 stroker's Avatar
97 stroker
1990 2.9 problems
Bought bronco ll not running ,new fuel pump filter ,fresh cap rotor ,wires ,plugs ,starts runs ,go to drive it misses no power ,checked compression all good and same psi , baffled need suggestion what to ck next,
Old Feb 16, 2017 | 11:10 AM
Josh S's Avatar
Josh S
A check of the OBD-I codes would go a long way in diagnosing. Whereabouts in Michigan?
Josh
Old Feb 16, 2017 | 12:26 PM
97 stroker's Avatar
97 stroker
2.9 problems
I live in midland, I ck that out thanks
Old Feb 21, 2017 | 03:53 PM
The.Green.Machine's Avatar
The.Green.Machine
Consider checking the ICM. I had one go out and it would just kill the engine when it warmed up and put it in gear, then I wouldn't be able to start it for an hour.
Old Feb 21, 2017 | 07:02 PM
97 stroker's Avatar
97 stroker
up date no codes when scanned key on not running , pulled plugs out #5 cylinder plug was wet ,checked injector electrical check ok ,has to be injector is failing mechanically ,going to replace injector ,see how that goes. To check code running , seen several way to start , what is the correct procedure to start scan? let if flash what motor you have then floor gas or hit brakes an turn steering wheel ?
Old Mar 8, 2017 | 12:27 PM
97 stroker's Avatar
97 stroker
figured it out last week checked all injectors electrically all checked good ,injectors an wire harness ,one failed mechincally ,replaced it runs like a top now !
Old Mar 10, 2017 | 11:49 AM
Josh S's Avatar
Josh S
Very happy to read you got it figured out.
Rion Jenkins
Bronco II
Feb 18, 2015 01:59 PM
F-150_XL
May 11, 2008 07:22 PM
80Bronco94
1978 - 1996 Big Bronco
Jan 23, 2005 03:35 PM
Semperfi45601
17
Oct 4, 2004 12:16 AM
crazydno
Bronco II
Mar 19, 2004 06:21 PM
