460 casting #s
Old Feb 14, 2017 | 04:55 PM
7379ford's Avatar
7379ford
460 casting #s
posting for a buddy, he has an 86 460 ford he's gunna rebuild it stock forum.. he's was wondering why some rebuild kits say 04-85-87 and others saying 72-3-85 what's the difference?? Thought 460s were the same from 79-87 for external balance. Thanks in advance
Old Feb 14, 2017 | 10:05 PM
wdfp's Avatar
wdfp
Probably different kits between the carbed and injected motors. The later ones had a little more compression and straight up timing gears plus different heads and intake .. The blocks are the same I think for all intents and purposes
Old Feb 15, 2017 | 07:12 PM
7379ford's Avatar
7379ford
I believe 88 was roller cam? Don't quote me. I know 87 carb had e6 heads and did they change intake? And what's strait up timing set ?
Old Feb 16, 2017 | 06:55 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
1988 model year was the first for fuel injection.
No roller cams in factory 460's.
The EFI heads had different port locations on both the intake and exhaust side.
'87 460 intakes were the same as any other square bore 4V carbed (non- CJ/SCJ) intake.
EFI trucks had a 'straight up' double roller timing set.
Earlier carbed versions had a 4° retarded timing set with a nylon cam gear that would get shredded and end up blocking the sump strainer.
"straight up" refers to the keyway orientation when the non-retarded crankshaft gear is installed.
Yes, you can swap an EFI timing set into a carbed engine.
Old Feb 17, 2017 | 06:05 AM
7379ford's Avatar
7379ford
Okay thank you for this info very much big help!!
norvillebob
May 3, 2016 10:22 PM
mdh1701
15
Nov 15, 2014 05:04 PM
mort2000
Mar 20, 2009 03:33 AM
Sycostang67
Apr 9, 2008 10:18 AM
jasgeer
Jan 27, 2005 07:38 PM
