460 heads?
Old Mar 19, 2009 | 12:26 AM
mort2000's Avatar
mort2000
460 heads?
i got an 88 ford with a 460 in it, and i got a heads off of a mid to late 70's era truck. will they fit on the later engine???? i also read some where to buy the timing chain set for a 1969 to 1972 as for did something to the timeing after 72' is there any truth to that??? thanks for your help....
Justin
Old Mar 19, 2009 | 01:25 AM
flamebuster's Avatar
flamebuster
Hey mort2000 welcome to fte. The heads on on a 88 are different if you have the efi. speed density air intake. The angle for the intakes are different from the carb. intakes.This is what I picked up in the big block forum. Havn't tried it myself. can't say on the timing chain I just installed a double roller on mine with no troubles ( it was labeled for an 88. there is lots of great info if you search the big block forum..
Old Mar 19, 2009 | 04:51 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Both the intake and exhaust ports are not the same and won't line up.
Post '87 EFI engines already have a "straight up" timing, and it's a roller chain set to boot.
Old Mar 19, 2009 | 09:05 AM
mort2000's Avatar
mort2000
The 88 has a carb its not efi....the only difference I se in the early amdltintakes was earn bore pattern
The intake runners and everything look the same.............thanks for all the help
Old Mar 19, 2009 | 09:18 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ford didn't put a carbed 460 in a pickup after the mid '87 model year.
Are you sure it hasn't been swapped already, or is this in a motorhome?
Old Mar 19, 2009 | 06:15 PM
mort2000's Avatar
mort2000
Its an F250 4sp 4x4. Might have to look at the vin tag. Might be an 87
Old Mar 19, 2009 | 07:22 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I think it is.
Check the build date on the door jamb sticker.
Old Mar 19, 2009 | 10:54 PM
mort2000's Avatar
mort2000
yep its an 87. so the older heads will work??
Old Mar 20, 2009 | 03:33 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes Justin they will fit.
You should get a aftermarket timing set that allows you to install the crank keyway "straight up"
