Used to FE blocks, wondering about 385 series
I just bought a 68 highboy and to my suprise it has a big block 385 series engine swapped into it, I wa's wondering if anyone has any information based on what I know (wich isn't much) except that it has D0VE-C heads and "D3VF A18" on the intake. I was wondering if anyone could tell the year range of the engine, and how I can tell if it's a 429 or 460, also info on starters would be greatly appriciated as the one that's on it doesn't meet up with the flywheel. I can get engine block numbers tomorrow if they help
Casting # for the block is behind the starter. The first letter tells what decade and the number is the year in that decade.... C 8 would be 1968, D1 would be 1971 and so on.
To find out 460 or 429 you can pull a spark plug and measure the stroke. Put a small dowel in at tdc and mark roll the engine over to bdc and mark again. Measure the diff to get the stroke. 429 = 3.59 and a 460 is 3.85...... Good luck on your project and let us know how it's going. Lots of pictures is always nice!!!!!
fordnutz66
09-09-2011 08:08 PM
robjs111
05-16-2008 07:14 AM
