Window crank
Old Feb 14, 2017 | 03:45 PM
jrotten67's Avatar
jrotten67
Window crank
My drivers door window is catching while rolling up or down. If I push or pull on the window it will start working again. There is a lot of slop in the crank stud. Is there a way to tighten this up or do I just need to get another crank assembly? Thanks.
Old Feb 14, 2017 | 04:18 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If you carefully remove the door panel and lube all the tracks/rollers and ck the division bar seal (pt#21546) is not slipped down or out of the track and lube the "regulator", you might be ok.
No adjustment of the regulator, when its worn out its time to replace it. FYI it is still factory it might be riveted in place, just drill them out and the replacement bolts in.
File Type: pdf
Old Feb 14, 2017 | 04:43 PM
redcreekauto's Avatar
redcreekauto
Most of the big parts chain stores can get them. They usually run around 40 bucks or so. At least in my area. They wear out but sometimes you can give them a good cleaning and get some more life out of them.
Old Feb 14, 2017 | 10:36 PM
jrotten67's Avatar
jrotten67
I'm going to guess it is shot. You can wobble the regulator stub around about a 1/2 inch it is not "tight" at all.
Old Feb 14, 2017 | 11:03 PM
77&79F250's Avatar
77&79F250
Yep sounds worn out.
Old Feb 14, 2017 | 11:09 PM
redcreekauto
Yep sounds like its time to be replaced.
katzklaw
Jan 14, 2016 02:30 PM
seven up
Feb 7, 2015 05:24 AM
Cerpindicular
Jan 9, 2011 08:12 PM
thaddeus
1947 and Older Ford Trucks
Aug 14, 2000 10:13 PM
