Tune up.
Old Feb 14, 2017 | 10:26 PM
Ford Guy87's Avatar
Ford Guy87
Tune up.
Ok i started buying parts to tune up my 400. My question is now bare with me. The truck is 78 F150 4x4. The motor was changed from the 351m to a 400 years ago by my grandpa with a motor from a 1974 vehicle (after checking block casting numbers). Assuming its from a car like a LTD. I been looking at fuel pumps. I see ones for the year of the motor but there some that say 4x4 only but are only listed for years of late 70s trucks. Does it matter which pump i get? Was there a difference in flow rate between a car 400 an a truck 400? Been hell finding correct parts not knowing the year of the motor till now.
Old Feb 14, 2017 | 10:34 PM
jrotten67's Avatar
jrotten67
If you already have it off the motor take it with you to the parts store and just look at both.
Old Feb 14, 2017 | 10:36 PM
Ford Guy87's Avatar
Ford Guy87
Not yet its my daily. They seem to look the same other then the direction of the inlet an outlet.
Old Feb 14, 2017 | 11:36 PM
DB429SCJ's Avatar
DB429SCJ
The 2WD truck and full size car use the same pump(carter M6882). It fits all 351M/400. Flow rate is not an issue. This should be the one on your motor.
Old Feb 14, 2017 | 11:37 PM
Ford Guy87's Avatar
Ford Guy87
Thank you very much for the help much appreciated.
78_f150
May 31, 2011 10:53 PM
OzarksFord
Nov 11, 2008 08:23 PM
lincoln c.
Sep 20, 1999 08:57 PM
paul bonfiglio
Sep 19, 1999 06:28 AM
