High delta!!!
Old Feb 24, 2017 | 01:50 PM
  #46
Justus6.0L's Avatar
Justus6.0L
Originally Posted by Bluepowerstrokin
Will flushing the system do me any justice??
You spelled it wrong... LOL
Old Feb 24, 2017 | 01:57 PM
  #47
navistarnut's Avatar
navistarnut
Ok so I've been shopping around to get my oil cooler replaced. (Don't have time to do it myself) I got quoted 1700 bucks for everything that sound about right?
Not entirely unreasonable. That's all OEM stuff correct?
Old Feb 24, 2017 | 02:41 PM
  #48
Bluepowerstrokin's Avatar
Bluepowerstrokin
Yeah all OEM and warranty
Old Feb 25, 2017 | 11:53 AM
  #49
Misky6.0's Avatar
Misky6.0
drove the truck this morning to go fishing went pond hopping pretty much and seen my delta at 192 ECT and 237 EOT!!! Will flushing the system do me any justice??
I would inspect the oil filter and cap and the valve/spring at the bottom.
You might have the wrong filter/cap pair and getting UNfiltered/UNcooled oil flowing through the oil cooler bypass valve at the bottom of the filter housing. This would be very bad, and with your EOT that high, seems more likely, if drop to idle (hpop pressure drops, you might see rapid drop in EOT)
OEM Ford Cap is short and NEEDS a Ford OEM filter, avoid the aftermarket brand filters that require their own cap to work "right", sometimes.
Old Feb 25, 2017 | 12:20 PM
  #50
jswartz84's Avatar
jswartz84
I probably haven't posted it enough, but I think you guys are barking up the wrong tree with the Oil Cooler Bypass Valve.
I drove around without a valve in there which would simulate the worst condition for a valve to be in and only saw a 12° difference in my EOT vs. ECT. When I installed the valve, my temp difference dropped to 7°.
Not saying that's what your blaming Misky, but that seems to be the buzz around here lately.
Old Feb 27, 2017 | 08:25 AM
  #51
Justus6.0L's Avatar
Justus6.0L
What valve are you guys talking about? I thought the issue was that the aftermarket caps are too tall, leading the filter to not reach the bottom, thus allowing unfiltered oil to get through the system. The Ford cap is shorter, which makes the filter come into contact with the bottom ensuring all oil is actually passing through the filter.
FL SuperDuty
Aug 2, 2018 09:03 AM
Kdawg89
Jul 19, 2015 01:59 AM
adammdennis11
May 29, 2015 06:31 PM
mark r / 019
Nov 25, 2013 08:52 AM
SqueeK
Sep 10, 2009 01:20 PM
