Headlight switch problem
Old Feb 12, 2017 | 04:43 PM
Four.on.the.floor's Avatar
Four.on.the.floor
I have a 1995 f150 5.0 xlt ext. cab.
A week ago I pulled out my headlights and the headlights came on but the taillight and interior lights were still off. I pushed in the switch very slowly and the interior lights flickered, so I thought, oh it has to be the headlight switch. After I fiddled getting the switch in the perfect spot all came on.
Yesterday I went to Orielys and got a new switch and I installed it in the parking lot, Well the damn thing did the same exact thing so I went back for a different brand and it did the same thing.
I am lost and I need some help before I wire in 4 different switches for each one.
Old Feb 13, 2017 | 12:46 AM
TexasGuy001's Avatar
TexasGuy001
Its possible that the connector for the switch has heat damage.
Old Feb 13, 2017 | 01:13 AM
The.Green.Machine's Avatar
The.Green.Machine
I'd try to put dielectric grease on all connector points on switch. Not permanent fix but should let you know if you got any loose or corroded wires
Old Feb 13, 2017 | 07:26 AM
jas88's Avatar
jas88
Check your fuses. The taillights and dash lights are on a different fuse than the headlights, IIRC. I did the same thing on my '90 F150 about 20 years ago, replaced headlight switch, found out my trailer had an intermittent short that blew the taillight fuse. I drove all the way home from AR to TX with the switch kind of in-between as you found to make the taillights work.
Old Feb 17, 2017 | 09:32 AM
Four.on.the.floor
Fused fixed it. Thank you.
ErrorS
1978 - 1996 Big Bronco
18
Feb 17, 2013 03:15 AM
joshofalltrades
Jan 22, 2013 07:29 PM
The other Joe
Jun 6, 2011 12:54 PM
Hank85713
1983 - 2012 Ranger & B-Series
May 7, 2009 10:22 PM
g-a-w-d
Aug 27, 2003 07:14 AM
