Hey, on my Truck, when im driving with the headlights on at night, the lights will be on for a minute, then off for a minute then on for a minute and so on. What would cause this? My dad seems to think its the dimmer switch.
Any Thoughts?
the dimmer switch is more then likely your problem. i had a 80 f250 that did the samething. changed the dimmer switch and all was fine. even if it's not it's a good place to start on the hunt of your problem since it's a point all the head light wires run thru from the fuse block
It's not likely the hi-low switch. It's the circuit breaker inside the headlight switch cycling because the circuit is drawing too much current. Do you have extra lights added to the headlight circuit? Put an ammeter inline from the headlight switch connector to see how much is flowing. If it's normal (~10A for both low beams), replace the switch. If it's high, find the drain.
I second the headlight switch. Old Mustangs in particular are well know for this along with a lot of Fords. The cure is a new headlight switch.
I had a 74 F100 that did the exact same thing, so bad I had to jumper a wire directly from the battery to the headlights to get home one night.
I've noticed a lot of 80's wreckers also have the problem regularly because of all the added running lights if they are not run through relays.
Originally posted by Txquadhunter24 the dimmer switch is more then likely your problem. i had a 80 f250 that did the samething. changed the dimmer switch and all was fine. even if it's not it's a good place to start on the hunt of your problem since it's a point all the head light wires run thru from the fuse block
The headlamps are not fed by the fuse block. They are fed direct power from a fusible link. This is why there is a circuit breaker in the switch itself. The headlamp switch then feeds the dimmer switch, which then feeds the lights themselves. The dimmer switch was a good place to look, since on the older trucks it's down on the floor where it can get corroded. If you have any added lighting to the headlamp circuit, this can overload the circuit breaker in the switch, causing the same problem. I would also inspect the plug on the switch itself. A loose connection there can cause heat, and will cause the circuit breaker to blink the lights on and off. Also inspecting the wiring like you said is a good thing to do. If all else fails, I would try a new headlamp switch.
I will vote for the headlight switch. I have had this problem with a couple of differant Fords, car and truck. Replaced the head light switch and lights would work fine.
