Sponsored by: Real Truck
need help finding aftermarket e-locker
Old Feb 11, 2017 | 08:33 PM
gustrider4's Avatar
gustrider4
hello all, i have a 2015 f350 without the electric locking rear. 3.73 gears. I want to buy a electric locking axle so when engaged both wheels are locked together and when open (off), basiclly act like a non-limited slip. A couple brands I found are Eaton, Auburn, ARB (air-locker) But i cannot find them in a Sterling 10.5, 35 spline, which i believe is the rear axle my truck has. The websites for these lockers did a horrible job in showing all the products. I would like to find the product, get a price and get a price from a axle shop to swap in. Thanks in advance
Old Feb 12, 2017 | 10:19 AM
Brad Brown's Avatar
Brad Brown
I will be looking for the same info!
I have a 2010, F250 that I am making into a hunting truck, it has the sterling 10.5 also. My hunting rig , 1974 Crew had a Detroit Locker which worked great. it was a none electric one, but I never had any issues that you always here of like turning sharply or anything like that. It just did its thing with no fuss at all. I will be looking for anything that works. Please keep me posted on anything you see from this forum! I will do the same!
Old Feb 12, 2017 | 10:24 AM
projectnitemare's Avatar
projectnitemare
The dealer is a place you haven't thought about. Aftermarket you'll see it listed as a 10.25. Don't worry it will still work but you will need the correct bearings.
Old Feb 12, 2017 | 01:34 PM
gustrider4's Avatar
gustrider4
I did find the oem one from the dealer. It is $1700 just to buy it. I will keep looking online and report back anything i find
Old Feb 12, 2017 | 01:41 PM
gustrider4's Avatar
gustrider4
Eaton 14022-010: ELocker Differential Dana 60 | JEGS
Heres the E-locker for the front, cant find one for the back
Old Feb 12, 2017 | 02:06 PM
projectnitemare
Think about it, dont know if you'll find an e-locker for the rear, most all of the selectables I know of are air operated. $1700 for a dealer locker is a little steep, my dealer treats me better than that. It still isn't going to be cheap, if you noticed the Dana 60 one is over a grand. The 10.5 is a bit larger and if the factory is the only option it will be more expensive. I do see them on eBay time to time.
Old Feb 12, 2017 | 02:09 PM
Chuck's First Ford's Avatar
Chuck's First Ford
start shopping on-line Used. 2011 to 2016....
or wrecking yards.
Old Feb 12, 2017 | 02:20 PM
gustrider4's Avatar
gustrider4
Ford 10.25" / 10.5" Axle Parts, Gears, and Upgrades
best bet is right here. this shop has the major air, electric, detroits
Old Feb 12, 2017 | 02:25 PM
projectnitemare
Randy's ring and pinion will have all the top brands also. Great customer support too.
Old Feb 12, 2017 | 06:29 PM
82_F100_300Six's Avatar
82_F100_300Six
Is the tru-trac good?
Old Feb 12, 2017 | 06:55 PM
projectnitemare
Trutrac is a much better option than a factory limited slip. Helical style rather than clutches. They are a good unit
Old Feb 13, 2017 | 01:14 AM
David_h's Avatar
David_h
For the ARB unit should be:
FORD STERLING 10.25/10.5" ARB® #RD140
AIR LOCKER FEATURES
Jarryd
Apr 19, 2013 11:39 PM
TexasRebel
Jul 10, 2012 07:59 PM
thebooger13
Oct 5, 2010 09:08 AM
jazzy66
Feb 23, 2006 05:05 PM
wojo1989
Oct 24, 2004 10:27 PM
