The pigtail from my bumper mounted 7-pin to the factory connector is all hacked up from the previous owner so I'm looking to replace that pigtail. Also wondering if there should be 2 connectors down there to add a connector for my gooseneck or do I need to splice another universal 7-pin into the bumper light pigtail? Also, is there another (preferably slightly cheaper) option besides e-trailer for such a connector?
Not sure what year Ford started putting a 7 pin plug in the bed. The ones wired for the bed 7 pin have two connectors behind the rear tire on the driver's side frame area.
You can buy the kit from Ford or go to the local pick and pull yard and see if any trucks there have it.
