1996 Trailer Harness Question.
Old Feb 27, 2005 | 09:45 PM
nzabka's Avatar
nzabka
1996 F150, 4x4 Northland Edition, 302.
I was working on getting my trailer light connector set up and found that the right blinker output is not working from the flat 4 pin connector that I plug my harness into, left blinker and park lights work just fine out of the same harness with the test light, so I know the ground is good. I used a test light all the way up to that factory flat 4 pin connector on the drivers side by the spare tire. The right blinker lights do work on the pickup and I replaced the flasher module with a heavy duty one.
Does anyone know exactly where the trailer plug wire for the right blinker interfaces to the actual right blinker circuit? It appears to all combine into split loom and go into the frame of the pickup. I ran out of day light and thought I'd see if anyone knew where they connect to eachother before I start ripping all the wiring out of the frame. I'm hoping the problem exists where ever these two wires are interfaced.
Thanks!
Old Feb 27, 2005 | 11:17 PM
95X15's Avatar
95X15
There is an aftermarket adapter that plugs into the round inline connector where your flat connector is -see if that connector is made up/ can be separated and plugged together in the harness -may just be a bad adapter that can be replaced along with the 4 pin flat in a kit. 95 manual show a splice at firewall that breaks out to the factory trailer harness and goes to a round trailer connector at the bumper. Seems like I got the adapter kit at a parts store. Good luck.
Old Feb 28, 2005 | 07:38 AM
bobcf's Avatar
bobcf
some of the trailer stuff comes frome the fuse box under the hood, on the drivers wheel well.
Bob
Old Feb 28, 2005 | 08:53 AM
nzabka's Avatar
nzabka
Yes, there is the round connector before the flat connector. I looked at it and it was clean and all, so I guess I didn't doubt it. I better check it with the test light to be sure. Hopefully that's it.
Thanks guys!
hairytrigger
1997 - 2003 F150
Feb 16, 2015 04:47 AM
wyckedcombo17
Jul 25, 2011 01:23 PM
Daisy Cutter
Electrical Systems/Wiring
Oct 2, 2006 01:37 PM
cjf5150
Oct 18, 2005 11:18 AM
bossmanbef
All Things Towing
Apr 5, 2003 06:36 PM
