How long to change injectors
Old Feb 5, 2017 | 04:28 PM
540milotalon's Avatar
540milotalon
A friend has a '05 F-550 and I ran the A/E on it and came up with 4 codes;
Turbo, CPS, PCM, and an exhaust pressure code. No inj. codes.
He took it to a shop since I was not able to work on in a timely manner and the dude told him it had 3 bad inj. and he would change them out for $280. each plus the core (refundable) and 4 hours labor @$90. per.
I do not believe one man can change out 4 inj. and turn it around in 4 hours. Is this a scam?
I had prices of $201. and $211. each for the inj. so there is a industry standard mark up.
Old Feb 5, 2017 | 05:29 PM
Sullid01's Avatar
Sullid01
If the three injectors are on the same bank, then 4 hours is pretty doable. A 6.0 tech that does a lot of these could probably do both sides in 4 hrs. Why no injector codes though? I think your friend needs to make sure they have the diagnosis right before he starts replacing things. And definitely want to insist on Ford reman injectors
Old Feb 5, 2017 | 05:43 PM
540milotalon
No, he supposed to change out all 8. I checked with the one supplier and he said same thing. Fix/check each code before buying the inj. Not one inj. code or problem when doing on board tests.
I dunno. I own/drive the 7.3 PSD myself and I know I can't change all 8 inj. in 4 hours.
Thanks!
Old Feb 5, 2017 | 05:52 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Use the AE and get a baseline Contribution Balance test.
Josh
Old Feb 5, 2017 | 08:12 PM
BLADE35's Avatar
BLADE35
Guess i would have to wonder why changing inject when dtc points to everything BUT INJECT
rare and maybe unheard of all 8 inject go bad
Sounds like he going to spend a bunch money and still have a broke truck
Old Feb 6, 2017 | 08:04 AM
Burgess090906's Avatar
Burgess090906
Ask for a screen shot from their IDS running an uncompensated contribution test.
If this is not available, then I would not authorize the repair. With no codes, this is the only way to diagnosis faulty injectors.
Old Feb 6, 2017 | 09:05 AM
2006powerstroke90's Avatar
2006powerstroke90
I mean you did say 4 injectors right there....which would be very do able.....but to change out all 8 like Benny said is almost unheard of unless someone filled the truck with gasoline instead of diesel...
I would find a different shop and get a different opinion before dumping all that cash!
Old Feb 6, 2017 | 09:26 AM
Per4mance's Avatar
Per4mance
I did mine in my Ex,all 8 in 6 hours with interruptions in my driveway. The only reason I changed them was because I had no history on the vehicle and I had no idea what was done for maintenance on the truck and it had over 200 thousand on the clock. You got to find a shop that has IDS or your just wasting money.
Old Feb 7, 2017 | 11:39 PM
Bumblebee04's Avatar
Bumblebee04
Whenever I get my big rigs oil changed they tell me I'm not allowed to be in the shop due to insurance regulations. I simply tell them my great west 1 million dollar insurance coverage blows the doors off their shop insurance policies as long as I'm with my truck. They normally don't give me any problems, but occasionally I have to teach the shop forman about insurance policies.
Granted our 6.0s fall under a different policy, but i would simply say if i can't see the work being done I'll take it elsewhere that I can.
typefour
Oct 8, 2019 08:49 AM
Lubbockguy1979
Dec 13, 2016 01:09 PM
El Camino Man
Aug 26, 2013 07:37 PM
med-care-guy
Sep 17, 2012 10:07 AM
FordManMT
May 31, 2012 03:38 AM
