"66" Under dash bezel chrome
Old 02-05-2017, 09:56 AM
swoosh1958's Avatar
swoosh1958
swoosh1958 is offline
I saw one of these on Ebay. Is this a stock part for a "66" Under dash chrome.
Old 02-05-2017, 10:30 AM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
For a '66 F100 or a '66 F250 2wd, no it is not. they had the "sweep" speedometer when ordered with the Custom Cab package. As for '66 f250 4X4's, I don't think so as mine never had it. F350's and up? Maybe, but I don't know.
I think they were mostly used on '61 to '64 F100 and f250 2wd custom cabs but somebody should be along shortly to give you the exact answers.
Old 02-05-2017, 10:34 AM
gangstakr's Avatar
gangstakr
gangstakr is offline
If you have the round type cluster than you can use it. If you have the sweep style, commonly on 65-66 f100's, than this item will not look right, nor sit right.
Post a picture of your dash. Also a picture of your ID tag on your door.
All information can be deciphered and you'll know weather or not you have a custom cab or not. That being said, your truck must also have the round type cluster.
Old 02-05-2017, 10:57 AM
swoosh1958's Avatar
swoosh1958
Mine is a sweep style speedometer. It is a Custom Cab. Just happen to see this on Ebay, listed as a 66. Made me think.
Old 02-05-2017, 11:59 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Use with round speedo chrome steel instrument cluster bezel: 1961/64 F100/1100 Custom Cabs; 1965/66 F350/1100 Custom Cabs.
Old 02-06-2017, 10:49 AM
Roger C's Avatar
Roger C
Roger C is offline
[QUOTE=swoosh1958;16926359]
I saw one of these on Ebay. Is this a stock part for a "66" Under dash chrome.[/QUO
I have one that I assume is it for a sweep Speedo. it is stainless steel with no Custom Cab. not sure how switch holes it has though. I am getting ready to sell this and a lot of other 61-66 and 67-76 parts. let me know of you want pictures. I recently had a stroke so my wife says start getting rid of my stash.
Old 02-06-2017, 11:40 AM
NumberDummy
1965/66 F100/250 2WD & 1966 F100 4WD Custom Cab & Ranger:
Not used with sweep speedo instrument cluster bezel.
Old 02-11-2017, 08:51 PM
aj64f100390-292's Avatar
aj64f100390-292
aj64f100390-292 is offline
also keep in mind the 65-66 dash bottom where the column mounts is round notched as they moved the column up for room...if it was me i would make a piece to close the round gap, and trim it on the bottom...65-66 dash has always looked naked to me...
Amphihauler
06-24-2016 08:39 PM
64 hi-boy
05-20-2010 08:49 PM
1966_F100
29
10-16-2009 04:55 PM
4x4lugnut
01-18-2008 04:19 PM
jcs1966
02-03-2004 05:34 PM
Quick Reply: "66" Under dash bezel chrome
