What happened to the Camper Package?
Not sure what config you are trying, but I know at least with the Powerstroke, the Camper Package will be missing until you change the axle ratio to 3.55 (accept the heavy duty requirement), then scroll back up and it will be there. The Camper Package doesn't appear if your axle is the default 3.31. Go figure.
Yep, you have to pick your axle ratio first before many options show up now. Axle selection used to be on the first page which cleared up this confusion but Ford moved it to 2/3rds the way down the option list on the second page. This really confuses things as after selecting it, you then have to scroll to the top and start all over again with the new options that then present themselves.
The 3.55 rear end is required to do either the camper package or snow plow prep. You also have to have 18" rims selected to do the camper package. Either the 18" or 20" rims are fine to get the snow plow prep. But you can't get both the snow plow prep and camper package.
Seem pretty straight forward?
Thanks for the info.
