No signal, no start
Old Jan 31, 2017 | 07:05 AM
1ole4d's Avatar
1ole4d
Cool No signal, no start
So this past weekend, after spending Saturday replacing the rear brakes on my F350, my truck decided it didn't want to try out the new shoes and won't start. When I turn the key you can hear the fuel pumps come on, the relays click but there is no signal going to the starter solenoid. I've been having problems with the transmission range sensor which I am almost 100% positive it is causing this no start. I have replaced it twice and both times the backup lights don't always come one and a couple of times I had this problem of not starting. I noticed if I wiggle the lever be hand at the transmission the backup lights will work. It's as if something electrical internally is screwed up. So, in my engineering creativeness, I installed a push button starter switch in the ashtry to bypass the ranger sensor until I can dive deeper into the problem. Between the electrical issues and the hard shifting with this transmission I'm about ready to swap it to a 5spd. Then again with this being a CA truck it wouldn't be that easy. Has anyone ever run into this problem of not starting?
Old Jan 31, 2017 | 08:43 AM
rla2005's Avatar
rla2005
What year/engine truck are you working on?
Old Jan 31, 2017 | 08:59 AM
1ole4d's Avatar
1ole4d
1996 F350, CA460.
Old Jan 31, 2017 | 09:04 AM
rla2005's Avatar
rla2005
Your issue is most likely the MLPS as you previously stated. You should also check the two torx head screws at the bottom of the steering column where the shifter attaches. Those frequently come loose.
Thanks to Subford:
Old Jan 31, 2017 | 09:07 AM
rla2005's Avatar
rla2005
A photo from Steve83 for where to align the MLPS notches:
Old Jan 31, 2017 | 09:14 AM
1ole4d's Avatar
1ole4d
Those two screws, is that where you can tighten the shifter lever to reduce the play back and forth?
Old Jan 31, 2017 | 09:25 AM
rla2005's Avatar
rla2005
If those screws are loose, yes.
Old Jan 31, 2017 | 09:34 AM
1ole4d's Avatar
1ole4d
Hmm, awesome. I'll have to check them at lunch time. Your picture from Steve83 didn't show up btw.
Old Jan 31, 2017 | 09:42 AM
rla2005's Avatar
rla2005
It does on the website. I find the same issue as you when using the FTE App. Sometimes images appear, other times they do not.
ScottInTexas
Dec 1, 2015 09:36 PM
tylert1976
22
May 1, 2013 09:43 PM
IBleedOvalBlue
Feb 12, 2012 06:08 PM
tje2015
27
Jan 24, 2012 07:27 PM
Cofooter
Jan 25, 2007 12:33 PM
