E99 PID's
Old Jan 30, 2017 | 02:45 PM
hotrodfeguy's Avatar
hotrodfeguy
E99 PID's
Do any of the pid's change for E99? I see the same PID number for multiple uses, you cant input 2 numbers to the same pid right? For example I see EBP and EGP on the same PID number.
Old Jan 30, 2017 | 04:37 PM
Chipworkz's Avatar
Chipworkz
Tugly is the master on this subject but yes you can have multiple gauges set to the same PID. It is the Name and Formula that is different.
Most are the same for the E99 and the only one I have that is different is the Transmission Temp.
A - Transmission Fluid Temperature TFT 221674 ((A*256)+B)/8 0 250 °F Auto
A - Transmission Fluid Temperature (E99) TFT 2211BD (((A*256)+B)*-0.0036)+212.98 0 250 °F C410F1
Here is an example of two different gauges but they use the same PID.
A - Exhaust Gauge Pressure EBPG 221445 (((A*256)+B)*0.03625)-[221442] 0 40 PSI Auto
A - Exhaust Gauge Pressure (TPD) TPD 221445 (((A*256)+B)*0.03625)-[221440] 0 40 PSI Auto
Old Jan 30, 2017 | 04:44 PM
Tugly's Avatar
Tugly
The numbers are the memory address to locate the PID information. It is crucial to get the memory address and the PID name exact, with no typos - or it can confuse the PCM and stall the truck. Once you have the correct data source, then it's a matter of what you want that gauge to feed you. Do you want Manifold Absolute Pressure or Manifold Gauge Pressure (Boost)? Do you want Exhaust Back Pressure (absolute), Exhaust Gauge Pressure (boost drive pressure), or Turbo Pressure Delta (difference between boost drive pressure and actual boost? Reading the same memory location and PID over and over for different gauges uses up a lot of screen real estate and PCM read time - so choose wisely. Getting MAP and boost is redundant. Getting EBP, EGP, and TPD is redundant. I pick my one favorite gauge for each sensor, then move on. For air in/out, I use Boost and TDP... very telling.
Diesel_Brad
Jul 19, 2015 08:03 PM
FiznUKa
Dec 20, 2014 09:20 PM
dothedew192
38
Feb 7, 2011 03:36 PM
79_250RangerLariat
19
Feb 9, 2008 06:59 PM
John311t
Jun 8, 2007 04:04 PM
