Fuel pressure
Old Jul 19, 2015 | 09:01 AM
Diesel_Brad's Avatar
Diesel_Brad
Fuel pressure
Hey guys I am FINALLY getting around to ordering gauges for my supercharged truck.(96 460 Vortech SQ)
I need to know what range Fuel Pressure gauge I need.
Also if anyone knows what boost/vac range
Old Jul 19, 2015 | 10:20 AM
Conanski's Avatar
Conanski
Are you using an FMU with it? The choices are carbed apps(0-30psi) or EFI(0-100psi), if not using an FMU pressure will never go above 45psi give or take but if you are you could see spikes up into the 60-70psi range.
Old Jul 19, 2015 | 11:50 AM
Diesel_Brad
Yes, FMU and it has a secondary pump that is triggered by a hobs switch
So 0-100 it is.
Any suggestions on a Vac/boost gauge? Or should I just run a boost gauge
Old Jul 19, 2015 | 11:56 AM
mrollings53's Avatar
mrollings53
I'd get the vac/boost gauge, tells you more information.
Where did you find the supercharger? Vortech doesn't make them anymore, and I'd like to install one in my truck.
Old Jul 19, 2015 | 03:02 PM
Diesel_Brad
I got it 5 years ago from a junk yard
Old Jul 19, 2015 | 03:22 PM
eakermeld's Avatar
eakermeld
This particular one only goes up to 60psi, but as far as the quality I really like it. One of the best gauges I have ever owned. This electric gauge has an attribute programmer available that you can fine tune the settings, like warning light, backlighting brightness, pressure readings, and filter out the pulsations. It is expensive, but well worth it.
Old Jul 19, 2015 | 08:03 PM
Diesel_Brad
Originally Posted by eakermeld
[IMG]
Thanks but i am trying to put 3 matching gauges in. And AEM has the only Wideband A/F gauge I could find to match the stock gauges so I am going with all AEM gauges. A little over $600 for 3 gauges and a A piller pod mount
Tugly
31
Nov 11, 2014 05:44 PM
richdawg
19
Apr 25, 2012 10:54 AM
2000F250guy
Oct 29, 2011 11:56 AM
Tylus
Sep 30, 2011 01:16 PM
matt71
Aug 25, 2008 07:12 PM
