EBPS (PCM reading) VS. EBP Gauge
Old Jun 8, 2007 | 02:42 PM
John311t's Avatar
John311t
EBPS (PCM reading) VS. EBP Gauge???
I just replace my ebps and tube! Its been broken for awhile now, the sensor I dont think ever worked since i bought the truck. I finally seen on AE the exhaust backpressure actually move when i hit the pedal.
My question is the PCM reading that AE says for exhaust backpressure, how does it compare to the gauge reading? Its more of i was wondering about it, and i will probably never run a EBP gauge, but wondering if they would be the same.
Old Jun 8, 2007 | 03:40 PM
Uzumati's Avatar
Uzumati
The EBPS reports absolute pressure and not gauge pressure so a secondary hard plumbed gauges should read EBPS - BARO
Old Jun 8, 2007 | 03:42 PM
John311t's Avatar
John311t
So if i wanted to figure out drive pressure it would be
EBPS - BARO = Drive pressure?
Old Jun 8, 2007 | 03:54 PM
Uzumati's Avatar
Uzumati
Yep, so if you have 10 psi backpressure and 2 psi boost the drive pressure ratio is 5:1
Old Jun 8, 2007 | 04:04 PM
John311t's Avatar
John311t
Thanks, now i dont need to think about buying a backpressure gauge for now damn pms.
tjmike
Feb 2, 2015 09:24 PM
SGorman13
13
Feb 14, 2014 03:33 PM
Ford4Life7.3
Nov 1, 2013 11:36 AM
JTQ0919
Jan 15, 2013 01:56 PM
j-bar
Jan 18, 2012 04:52 AM
