Sponsored by: Real Truck
Remote Start Not Working
Old Jan 28, 2017 | 03:25 PM
cecilt's Avatar
cecilt
The factory remote start is not working on my 2009 F 250. The red light is lit when I push the button, the doors lock and you can hear something engage in the engine but it does not crank it. If I keep holding the button the alarm starts to go off. When I walk up to truck the radio is on and I need to hit the remote start button to shut everything down before manually staring. Any ideas? tks
Old Jan 28, 2017 | 03:47 PM
Just Strokin's Avatar
Just Strokin
Some Ford remote starts will not work if you have a CEL or codes. I would suggest you check to make sure not codes stored.
Old Jan 28, 2017 | 05:08 PM
seville009's Avatar
seville009
I'd change the battery in the remote first, just because it might end up being a simple fix. Even though you're getting something now, it may not be enough.
Also make sure your hood is shut tight; just open it and slam it shut.
Old Jan 30, 2017 | 01:55 PM
cecilt's Avatar
cecilt
In thinking about this, the dealer had to replace my body control module in September last year. I never use my remote start and probably have not in a year but tried it over the weekend which is when I discovered it would turn on the inside radio and attempt to start but does not. Could the dealer have forgotten to program it back? Does it even need reprogrammed after replacing a BCM? tks
Old Jan 30, 2017 | 05:45 PM
Masterofyard's Avatar
Masterofyard
A friend had the same problem. The dealer had to reflash the computer for the auto start. It seems to be a problem on the older auto starts.
JEB63
Jan 26, 2019 05:04 PM
Steve White
Dec 18, 2017 10:14 AM
Olytlr
2009 - 2014 F150
Oct 1, 2016 03:16 PM
William A Volz
Michigan Chapter
Dec 24, 2014 06:33 AM
William A Volz
2004 - 2008 F150
Dec 18, 2014 05:11 PM
