TPMS and Camera Install Questions / Observations
Old Jan 27, 2017 | 07:05 PM
twesslen's Avatar
twesslen
Hello All,
Got my F250 Platty and finally introduced her to the travel trailer. Got the TPMS sensors installed. Was scheming on how to run the cord for the wired camera and have not figured that out yet as the route on the Airstream is eluding me.
In the meantime, I figured I'd at least get the TPMS sensors working. Seems to set up ok, but the major problem I see is that if I don't end up using the wired camera (seriously considering a voyager or another wireless one) then I have to have a huge piece of wire hooked into the "extra" hookup provided in the TPMS / Camera kit.
Question 1.) Is there a way to get whatever is built-in to the truck to monitor trailer tire pressures? IN other words, only install sensors and trick the truck into picking them up without using the TPMS/Camera receiver module.
Question 2.) If the answer to question 1 is no, is there any dongle or accessory that can be used to plug in the TPMS receiver and hide it behind the bumper on the truck? It almost seems like this could be done with a little inginuity if one could deconstruct the replacement for the 4-pin adapter and then shorten the cord significantly. This could then be tucked up under the bumper and all of the sudden you could easily monitor your trailer tire pressures without having a huge mess of cords lying around.
Thanks in advance for any thoughts or observations on this.
Old Jan 27, 2017 | 07:36 PM
wb6anp's Avatar
wb6anp
It may be a range issue also if the module is on the truck it may be too far from the sensors to pick them up. The module holds the memory to maintain the programming for the sensors. I believe the module is only for the TPMS not the camera, Maybe clip the wires for the camera? I thought the camera cable plugged in after the module, Not near my TT to look. According to this thread https://www.ford-trucks.com/forums/1...-tpms-kit.html the camera cable plugs in after the TPMS module, which I actually mounted between the axles on mine, so It would be easy to not install that part of the harness. Does the Airstream have a rear ladder? I just zip tied my camera to the ladder and ran the cable up it.
Midnite150
Nov 23, 2020 10:41 AM
nairod
2015 - 2020 F150
Sep 3, 2017 02:42 PM
ncred02
Mar 8, 2015 06:23 PM
OnDaRoad
May 28, 2013 12:18 AM
NJbronco138
1978 - 1996 Big Bronco
May 11, 2003 10:34 AM
