Sponsored by: Real Truck
Trailer Module fault
Old Feb 22, 2015 | 03:27 PM
ncred02's Avatar
ncred02
Im getting this almost every time I start it up. It happened once about a month ago, then more often. Now almost every time.
Truck has 1700 mi
I hate to have to bring it to Ford so soon
Old Feb 22, 2015 | 06:11 PM
ncred02's Avatar
ncred02
anyone else have this issue?
Old Feb 22, 2015 | 06:14 PM
JWC 3's Avatar
JWC 3
Are you showing faults ? I see the plugs on the rear of the truck short out from moisture and corrosion .
Old Feb 22, 2015 | 06:16 PM
JWC 3's Avatar
JWC 3
The weatherpak quick connect holds moisture .... is what I have seen . Causes various and random faults to show .
Old Feb 22, 2015 | 06:33 PM
ncred02's Avatar
ncred02
JWC I will check the plug in the morning. I may hit it with a heat gun or blow dryer and see what happens.
thanks
Old Feb 22, 2015 | 06:51 PM
JWC 3's Avatar
JWC 3
If that turns out to be the problem , dielectric grease may help after you get it cleaned out . Best of luck ! Let us know what you find .
Old Feb 23, 2015 | 10:58 AM
FordService's Avatar
FordService
Official Ford Rep
thanks
Any news for us today, ncred02? Let me know if you decide to get your dealership involved and I'll look into options to assist.
Crystal
Old Feb 24, 2015 | 12:01 PM
ncred02's Avatar
ncred02
It didn't do it yesterday at all. Didnt even dry or clean anything.
It just stopped.
Today I got what sounded like an exhaust gasket tick but that went away too.
This truck has me worried
Old Mar 8, 2015 | 06:23 PM
ncred02's Avatar
ncred02
Here we go again. Add to this I started it up this morning and the cold idle RPMs were going up and down as if someone was stepping in the gas
johndeerefarmer
Jun 3, 2024 06:57 AM
Rtortorello
Jul 20, 2016 10:23 PM
missionarymike
Mar 22, 2014 08:16 PM
Ford Fx4
2009 - 2014 F150
39
Mar 28, 2012 09:15 PM
twinpine
All Things Towing
Aug 1, 2010 09:17 PM
