e4od keeps losing main seal
Old Jan 11, 2009 | 10:36 AM
Dstosh's Avatar
Dstosh
I've got a '96 F-350. We do some snow plowing with it. One storm, the o/d light came on and flashed for a bit. A few days later while plowing, the trans lost all fluid and wouldn't move. When I got it back to my shop, I read the codes and one that came up was a trans over heat code.
Pulled tranny and replaced main seal, and all was well for about 3 hours. This morning while plowing about 3-3 1/2 hours in (Enough to get hot) the trans lost all fluid again. It was pouring out of the inspection cover so i assume it is the main seal again. I am heading back over to the shop to read the codes and pull the trans again.
Would an overheat cause the seal to fail like that? I have been plowing with this truck for 4 years, and haven't had it overheat. Could the cooler lines be plugged? Can a tranny cooler fail?
Thanks
Derek
Old Jan 11, 2009 | 05:48 PM
Dstosh's Avatar
Dstosh
Pulled codes, trans overheated. Anyone have any ideas? There was no fluid out of vent cap. Shouldn't that vent before the seal blows?
Old Jan 12, 2009 | 07:49 AM
wtroger's Avatar
wtroger
This is a common problem the seal will get hot and cause major leak when it cools off it will hold fluid again . My cure for this was to install and upgraded seal there is a better one avaliable can't remember the name of it. and then put a very large after market tranny cooler on it with a temp gauge. no issues since.
Old Jan 12, 2009 | 08:08 AM
Dstosh's Avatar
Dstosh
Any idea where you got the upgraded seal? Or what it is called? Thanks
Old Jan 12, 2009 | 06:13 PM
wtroger's Avatar
wtroger
Oklahoma transmission supply. [I] believe the upgraded seal is a vitron seal.
Old Jan 16, 2009 | 04:16 AM
icrman's Avatar
icrman
A plugged oil cooler can cause seals to leak on some transmissions.
Slash19
May 11, 2024 09:06 PM
Borgia
Nov 25, 2015 09:18 PM
lawdawg79
Jun 1, 2015 10:47 AM
enosez
Feb 27, 2015 06:30 AM
LANGEVETTE
25
Jan 19, 2011 04:31 AM
