I have run Autolite 25's gapped at .50 for years in my '95 5.8 XLT. I see that 24's at .42-.46 are recommended. I do run an MSD coil as well. Great power and decent mileage considering.
I notice that the 25's are about an 1/8" deeper and but one step hotter versus the AL 24's.
Any opines as to this application? I've never had an issue, but I am also not an internal engine guy. Seeking information on what running with this set-up means to the truck.
25 is a hotter plug than a 24. This means it burns hotter to keep the plug clean, but this does not mean hotter is always better. Too hot burns the plug up and can damage the piston in extreme cases, although 1 step hotter is not going to cause this. You should examine your plugs to see if there is any blistering on the negative electrode or any material loss.
The wider gap is helpful to ignite lean mixtures as long as your coil can keep up. Too wide a gap would cause misfire under load (when the mixture goes rich).
If you are not experiencing these issues, then I would say just keep doing what you are doing. You are not radically far way from stock specs on heat range or gap.
What do you think about the added 1/8" into piston which is also a difference between the 24/25?
Much THX.
Half an inch (.50) sounds a little big for the gap to me...
