Spark Plug 101
Old Nov 13, 2003 | 10:10 AM
Crumm's Avatar
Crumm
Spark Plug 101
What spark plugs do you all run in your 360/390's? What gap do you run?
I just changed mine. I installed a set of Autolite 45's and gapped them to .044. I am asking what you all do because the plugs I pulled out were Autolite 35's and were gapped to about .030. I have no idea how long they were in there since I just purchased the truck but from looking at Autolite's web site I cannot even find a 35 plug. I am wondering what the difference is and why they were gapped so close. Looking at there number system I think the 35's were a non-resistor plug with the same heat range as the 45 but I don't know for sure since they don't even seem to carry them anymore.
Old Nov 13, 2003 | 12:16 PM
rebocardo's Avatar
rebocardo
.035 Autolites or Bosch.
Old Nov 13, 2003 | 02:51 PM
Freightrain's Avatar
Freightrain
.044 might be a stretch for a stock coil.
If you have starting problems or running rough, it may be from trying to jump such a large gap with a small "stock" voltage coil.
Usually if you run a MSD they tell you to open the gap to .045.
Larry
Old Nov 13, 2003 | 03:45 PM
proeliator's Avatar
proeliator
Autolite 45s gapped to .50. But I've got a hot ignition.
Old Nov 13, 2003 | 04:52 PM
bikerwolfie's Avatar
bikerwolfie
Autolite 45s gapped to .45 with accel super coil.
Old Nov 13, 2003 | 06:08 PM
ZombieSlayer's Avatar
ZombieSlayer
Autolite 45's gapped to .50 with no dizzy...yet.
Old Nov 13, 2003 | 09:59 PM
Crumm's Avatar
Crumm
Well it looks like Autolite 45's are the most popular.
I am experiencing a little bit of ping when accelerating. Could it be from the .044 gap? The book calls for a .044 gap but would I maybe do better with about .040 or something since I am running the stock ignition?
Old Nov 13, 2003 | 10:05 PM
BB's Avatar
BB
What's your stock ignition, Duraspark?
Barry
Old Nov 14, 2003 | 12:49 AM
Crumm's Avatar
Crumm
I have no idea. Looks to be just a normal old stock ford setup. Would it say Duraspark somewhere?
Old Nov 14, 2003 | 12:54 AM
pat67shorty's Avatar
pat67shorty
NGK's gapped to .45 with MSD 6AL.
Old Nov 14, 2003 | 03:26 AM
bikerwolfie
duraspark would be fords electronic dist. with the module box. just installed it on mine, cost 120.00 and has been the best performance improvement i've made yet.
Old Nov 15, 2003 | 08:50 AM
dinosaurfan's Avatar
dinosaurfan
sparkplugs
Crumm, for plugs I like to run BF42s in the summer and BF82s in the winter. I know those numbers are out of date, maybe someone can translate for us. I also run a .080 plug gap, but I have a very healthy ignition. The bigger gap won't make it ping, but too warm of a plug might. There used to be a BF32 that some guys ran in the summertime...is there a new number for those ? DF
Old Nov 15, 2003 | 10:56 AM
Ratsmoker's Avatar
Ratsmoker
You better have good wires if you are going to run the .080 gap like DF. That kind of gap will destroy a set of autozone cheapies.
Old Nov 15, 2003 | 12:00 PM
rusty70f100's Avatar
rusty70f100
I'm running .45 on Bosch Platinum plugs, an Accel Super Stock coil, and high energy 8mm plug wires (I cant remember the brand). And I'm still running points! This setup seems to work good, but it eats up dist caps and rotors. Maybe if I didn't get the cheap ones it'd help.
Old Nov 15, 2003 | 12:23 PM
dinosaurfan
spark plugs, wires
Rat, I'm running moroso blue max spiral core at this moment. It does seem like the plug wires don't last as long as they ought. I don't think I would use any wires from autozone on anything. I had my best luck with some stranded copper wires, also from moroso, but they did strange things to my neighbors TV and radios, so I changed them. DF
