Gaps?
Old Jun 6, 2001 | 12:54 PM
Pastmaster's Avatar
Pastmaster
Gaps?
Does a closer gap mean more mpg, but less power? Or does it make a difference? I know that as a plug ages the gap widens. But I was always told to run a bit closer gap to provide better mileage. Any ideaS?
Old Jun 6, 2001 | 04:44 PM
stevieray's Avatar
stevieray
Gaps?
I have also wondered about the effects of different gapping. My old truck, a Ranger with an 8 plug head, was so hard to get at the [pluggs I left it fro 2500-km and finally changed them out of guilt. The gap on the plugs was huge, near .070!, but the truck ran fine. My new truck is a 93f 150 with a 5.0 and I recently changed plugs wires and rotor and cap in a quest to cure a missing problem(i didn't). I gapped the plugs to the recomended gap on the sticker on the hood,.044. The truck still misses. I tried a test plug hooked up to view the spark and it seem very weak, kind of pinkish not a fat blue spark that I would expect to see. Even my lawnmower has a better looking spark! Perhaps my coil is going south. I did try different gaps on the test plug but to no avail, still wimpy. I Do believe that the larger gap gives a hotter burn if the coil is up to it. Most modern engines use a bigger gap than they did years ago where .025 was the norm. My new plugs seem to be of a nice cafe au lait color with no deposits on the as were the old ones I took out. The gap on the old ones had worn into .050. The truck runs fine except for an idle miss and a miss when going up hill, but this miss corrects itself after a while. I am at a loss now so I will get the coil tested if I can to see if it is o.k. Any other suggestions? P.S. the engine light doesn't come on at all.
Old Jun 6, 2001 | 11:25 PM
PAUL_2's Avatar
PAUL_2
Gaps?
Ive always gapped the plugs on my engine at the upper range . The range is 044 to 046 . You always want the widest gap possible to produce the best spark , At least with conventional plugs . Another thing Ive found is the gap really doesnt change a lot in 15 to 20K miles . Thats about the life span of any Motorcraft spark plug .
Old Jun 7, 2001 | 09:11 AM
whomrig's Avatar
whomrig
Gaps?
Old Jun 7, 2001 | 11:24 AM
Franklin2's Avatar
Franklin2
Gaps?
I've read that a larger gap produces a larger spark for improved combustion which equals more power and better gas mileage. But as in all things there is a trade off. With a wider gap, you have to change the plugs more often and your ignition system has to be in tip top shape. The factory gap is a happy medium in plug life span and power/gas mileage.
73FOMO
Apr 28, 2009 02:39 PM
5.4L to Freedom
Feb 20, 2008 10:59 PM
biz4two
Modular V10 (6.8l)
Sep 30, 2006 07:31 PM
SAUKA
Electrical Systems/Wiring
Jan 14, 2004 10:43 AM
Pastmaster
Mar 28, 2000 08:32 PM
