1990 throttle linkage
Old Jan 22, 2017 | 12:34 PM
Oldhoss's Avatar
Oldhoss
Have 1990 Ford F350, gas 7,5l FI, unable to control throttle, will not return to idle after depressing pedal, appears that a spring is missing to return throttle back to idle, Ford dealer cannot find part. works fine after applying a return spring from pin on throttle linkage to engine. any help in finding proper repair would be appreciated.
Old Jan 22, 2017 | 01:33 PM
Conanski's Avatar
Conanski
The spring is coiled around the post under the linkage.. or at least that is where it's supposed to be, if yours is broken or missing then consider replacing the whole throttlebody.
Old Jan 22, 2017 | 01:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Oldhoss
Have 1990 Ford F350, gas 7.5L EFI, unable to control throttle, will not return to idle after depressing pedal, appears that a spring is missing to return throttle back to idle,
Uh huh...
Look at the 9B569 spring in the pic, notice the black dot. Black dot at the bottom of the pic sez it was only furnished with the 9E926 assembly.
So, the dealer was looking for a part that was never available by itself. Ridiculous!
Pic from 1980/89 catalog showing 1988/89. Pic is the same in the 1990/2001 catalog, but I cannot post pics from this catalog because it's on microfiche.
Old Jan 22, 2017 | 05:08 PM
Oldhoss's Avatar
Oldhoss
Smile Many Thanks
Many thanks to all...... will take info to dealer parts dept!
Carmz
Jun 2, 2018 06:44 PM
itinerant
1983 - 2012 Ranger & B-Series
Apr 10, 2012 05:26 PM
Samstha
Sep 8, 2009 03:12 PM
pdqford
Apr 5, 2009 12:57 PM
FirstF150
Feb 11, 2002 08:45 PM
