1990 throttle linkage
Have 1990 Ford F350, gas 7,5l FI, unable to control throttle, will not return to idle after depressing pedal, appears that a spring is missing to return throttle back to idle, Ford dealer cannot find part. works fine after applying a return spring from pin on throttle linkage to engine. any help in finding proper repair would be appreciated.
The spring is coiled around the post under the linkage.. or at least that is where it's supposed to be, if yours is broken or missing then consider replacing the whole throttlebody.
https://cimg7.ibsrv.net/gimg/www.for...034f1691ef.jpg |
1 Attachment(s)
Originally Posted by Oldhoss
(Post 16889386)
Have 1990 Ford F350, gas 7.5L EFI, unable to control throttle, will not return to idle after depressing pedal, appears that a spring is missing to return throttle back to idle,
Ford dealer cannot find part. :-huh Uh huh... So, the dealer was looking for a part that was never available by itself. Ridiculous! Pic from 1980/89 catalog showing 1988/89. Pic is the same in the 1990/2001 catalog, but I cannot post pics from this catalog because it's on microfiche. |
Many Thanks
Many thanks to all...... will take info to dealer parts dept!:):-drink
