Carburetor ID Help
Old Jan 22, 2017 | 10:54 AM
doublenickel's Avatar
doublenickel
Carburetor ID Help
can anyone help me identify the carburetor that is on my 312 YBlock? see pics
Old Jan 22, 2017 | 12:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Appears to be a Ford/Motorcraft 2100
Old Jan 22, 2017 | 01:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Auto-Lite/Motorcraft 2100 series 2V. This is the 1962/69 type. 1970/74 type has a choke pull-off diaphragm mounted on the air horn (top of the carb).
If you need a carb kit: D4AZ-9A586-A (replaced C2AZ-9A586-B) .. Auto-Lite/Motorcraft 2100 series 2V Carburetor Kit (Motorcraft CT-499-D) / Available from Ford & auto parts stores.
1962/74 Trucks/Passenger Cars; 1966/74 Bronco; 1969/74 Econoline.
Old Jan 22, 2017 | 02:07 PM
rico56's Avatar
rico56
At the side of the carb (as partly visible in the left picture) You'll find
the size of the venturi (for example 1.14 or 1.04 ...). If You're looking
for a replacment of the carb, make sure, the new one has the same
venturi.
Old Jan 22, 2017 | 09:55 PM
cgrocen's Avatar
cgrocen
On the side of the left front mounting flange, right by the bolt, there will be a code stamped. Something like C4AE-B, or 4AE-B, or something similar. If you can post that, then the carb can be identified.
Chris
joamariel
Oct 20, 2014 12:29 AM
CougarJohn
Jan 3, 2013 03:25 AM
crazed87bronco
Feb 7, 2012 08:08 AM
73' f-100
Sep 21, 2010 07:07 PM
croosteringa
Sep 19, 2010 11:14 PM
