Carb identity
Old Sep 21, 2010 | 02:46 AM
73' f-100's Avatar
73' f-100
Carb identity
I can't seem to find this carb anywhere. It is on a 73' F-100 with a 360. Mastercraft 2bl. and as best I can tell the tag on the carb says D3TF-DE A 3E 1. Just wanting to get any info on this thing I can. Thanks
Old Sep 21, 2010 | 03:21 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 73' f-100
I can't seem to find this carb anywhere. It is on a 73' F-100 with a 360, Motorcraft 2bl. and as best I can tell the tag on the carb says D3TF-DE A3E 1. Just wanting to get any info on this thing I can. Thanks
Welcome to FTE
Do you need the carb, parts for the carb, or a carb kit?
D3TF-DE = D3PZ9510BV .. Motorcraft 2V Carburetor (Motorcraft CA1804) / Obsolete
A3E = Assembled the 4th week (E) of January (A), 1973 (3) / 1 is the assembly plant code.
D4AZ9A586A (replaced C2AZ9A586A) .. 2V Auto-Lite/Motorcraft Carburetor Kit (Motorcraft CT499D) / Available from Ford and a gazillion autoparts stores.
Fits ALL 1962/74: 2V Auto-Lite/Motorcraft carburetors installed in Passenger Cars, Trucks, Bronco's & Econolines.
1970/74 2V carbs are essentially the same, have a choke pull-off diaphram mounted on the airhorn. 1962/69 2V's do not have this feature.
Old Sep 21, 2010 | 07:07 PM
73' f-100's Avatar
73' f-100
Thanks for the information. As of right now the only problem is it is acting like it has trash in one of the needle valves, I am going to try and clean it. I just could not seem to find any info on this thing and was wanting to see what I could find. I would like to find a spare carb, right now I have a lead on another 73' model but don't know what motor is in it or if it has a carb even on it or not.
KOMBILOVE
Mar 8, 2016 09:21 AM
F-ing 100
Aug 18, 2015 11:11 PM
Somenewguy
May 25, 2012 04:48 AM
tl1965
Sep 25, 2008 04:43 PM
Lukes66
Mar 27, 2003 06:53 PM
