Wheel offset pictures
Old Jan 23, 2018 | 09:58 AM
Jsfleming58's Avatar
Jsfleming58
@Robert.Jean1 that's such a sweet looking setup. I wanted to do the same wide offset but was afraid of rubbing with 35s, what size lift do you have on that?
Old Jan 23, 2018 | 10:10 AM
stewy604's Avatar
stewy604
Check out the various Ford truck Instagram feeds as well, like @Alumiduty. I actually did a lot of my research on fitment, lifts, etc... on there.
Old Jan 23, 2018 | 12:51 PM
Robert.jean1's Avatar
Robert.jean1
Thank you for saying so. I have a 6” Full Throttle Suspension kit on it. With 37” tires I have zero rubbing even at full articulation.
Old Jan 23, 2018 | 06:09 PM
Snowman 8's Avatar
Snowman 8
MotoMetal 20”x9” 0 offset wheels with Nitto G2 35x11.5x20 tires. The truck also has a 2” Fabtech leveling kit.
Old Nov 23, 2019 | 01:36 PM
FaceyourGiants1's Avatar
FaceyourGiants1
F250 sd lariat
Just got a quote to install 2.5 level kit in the front, fuel 20x9 with 35’s nit grappler 12.5 -19 offset. The guy said it will stick out about an 1.5” and I dont want to use flares. the guy at the shop suggested not to go over 2” outside the fender if not doing a lift, anything beoynd than 2” sticking out need a lift and flares to make look good. The higher the lift the more you want tires to stick out. In my case i am using stock suspension with 2.5” level kit and those tires.
What you guys think is it a good proportion? I want to avoid having undersize wheels and tires and dont want to look wide and stock suspension would also look weird.
Old Dec 7, 2019 | 07:41 AM
MBaldo's Avatar
MBaldo
Nitto Ridge Grapplers - 35 x 12.5
-24 Offset
Fuel 20" Lethal Rims
Works well with the Bushwacker Fender Flares
Old Dec 7, 2019 | 09:19 AM
Sonny Crockett's Avatar
Sonny Crockett
20 x 9 +18, 37's
Old Jan 22, 2021 | 07:19 AM
hendu4672's Avatar
hendu4672
Originally Posted by Sonny Crockett
20 x 9 +18, 37's
That looks awesome. Are those 12.5 wide? and I'm guessing a 2.5 leveling kit?
Old Jan 22, 2021 | 07:48 AM
pdose's Avatar
pdose
I’m looking at some Method wheels in a 20x9 to mount 295/65/20s on. They’re -12 offset. They wheel/tire guy says it will stick out about an inch. Could anyone confirm or deny this estimate? The truck is not lifted. I’m replacing the wheels because the PVD finish is flaking and I’m not interested in refinishing them
Old Jan 22, 2021 | 08:34 AM
hendu4672's Avatar
hendu4672
So the -12 offset will move you almost exactly 2" farther out than the stock 20" wheel/tire combo (stock 20's are +40 offset). And the 295/65's are a little more than an inch wider than stock. So add a 1/2 inch to each side. So by the end you'll be about 2.5" farther out than you are now. I think a -12 will end up being quite a bit more than 1" outside the fender.
Old Jan 22, 2021 | 08:39 AM
Painted Horse's Avatar
Painted Horse
I had the Ultra Predators 20x9 -12 and ran 295/65R20s and that's about what they stuck out 1"
I had no rubbing stock or when leveled
Old Jan 22, 2021 | 10:42 PM
NWnative's Avatar
NWnative
295/70-18 on Fuel 18x9 20mm Offset. Had them installed today.
CodaMan
Oct 28, 2016 02:11 PM
samtye
Dec 1, 2007 06:02 PM
jayboe
1966 - 1977 Early Broncos
Sep 12, 2006 09:51 PM
texag87
Jan 24, 2005 11:17 PM
NY-Ford-Lifer
2004 - 2008 F150
Apr 12, 2004 01:31 PM
