Which Hubs?
Old Jan 20, 2017 | 04:39 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Question Which Hubs?
I'm getting ready to replace Blue Ox's front wheel bearings and figured while things are apart, i might as well replace the front manual locking hubs.
What are some of the FTE community recommendations ?
Warn, Mile Marker, or rebuild the originals ?
I'm currently piecing together a Meyer snow plow set-up and it's probably best to be prophylactic (i'm sure Chris or Karl will chime in ) with the front end before pressing it into any kind of "somewhat" severe service.
She won't be plowing parking lots or anything near that size...just driveways.
I picked up some steel plates (the same used in road construction projects to cover sinkholes), in numerous sizes to use in the bed for weight.
The different sizes should allow for decent weight distribution while still allowing the bed to be used for hauling. As always, opinions are appreciated.
Old Jan 20, 2017 | 06:52 PM
Franklin2's Avatar
Franklin2
If you have the stock metal hubs, I would keep them. The aftermarket metal hubs are very expensive, the cheaper ones are plastic. If they are in good shape, no reason to change them. Just make sure you don't over do it on the grease, and try not to get a lot of grease in the hubs. In cold weather it gets stiff and they won't work.
I had a Meyer 7.5ft on my 1980 f150, I had to raise the idle speed up so it would lift the plow. It did fine when I did that, I had the stock alternator and a stock sized battery.
I have it on my diesel now, and with the dual batteries and larger alternator, the plow raises up with authority.
Old Jan 20, 2017 | 07:07 PM
WhatsAChevy?
The original hubs haven't given me any reason to doubt them so far. They have worked well in the minor snow up here to date. If i rebuild them, i will use red grease with an aluminum substrate suspension (like used on 5th wheels during winter months) to avoid cold temp coagulation. I do have the factory dual battery option and both batteries are less than 3 months old at matching 800 cca each. The only drawback is, I haven't converted to 3g yet.....yet.
Old Jan 20, 2017 | 08:42 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I have MM hubs on my D60. Mechanically they work great. Unlock/Lock with authority. Have never frozen despite all the slush/rain/ice and snow
however, the caps fit loosely on the flange. all the allen bolts are tight. maybe I'm missing a seal or something, but to me it seems off.
Old Jan 21, 2017 | 06:45 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I had Superwinch hubs on my D44 HD truck.
A bad U-joint allowed the axle to pull back and destroy the passenger side.
Replaced with Warn premium. ($100 next day from Amazon)
They've all worked fine for me.
Old Jan 21, 2017 | 12:17 PM
Nothing Special's Avatar
Nothing Special
My truck came to me with MileMarkers. One of them had the same loose cap issue Tylus mentioned.
I replaced them with Warn Standards. Had trouble with one of them popping out of the "free" detent and locking itself when I didn't want it to.
Returned them under warantee and put Warn Premiums on it. Their expensive (at least compared to the other options), but I've never had any trouble with them, including the one that caught the weight of the front end of my Bronco when the tire fell off a rock.
stevemcklin
27
Jul 22, 2016 08:49 PM
husky390
Sep 22, 2012 11:07 AM
79redranger
1983 - 2012 Ranger & B-Series
Feb 18, 2004 08:43 PM
SDElwood
May 21, 2003 07:43 AM
rustynuts
Dec 25, 2002 07:49 PM
