Trickle Charger
Old Jan 19, 2017 | 09:22 PM
1 Excursion camper's Avatar
1 Excursion camper
I have a Stanley brand 1.5amp battery maintainer for my X. I don't drive it much anymore. Only for towing our TT. It has worked perfect. You can hardware it to the battery so all you would have to do is either unplug the 12V connector or set it up so the 110V plug is just outside the bumper/grille.
Old Jan 20, 2017 | 04:12 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I installed a Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps and it's worked perfect for me. I was having an issue with battery drain after 5 days which seems to have gone away on it's own but I can plug it in and forget it.
Same unit we use at work for trucks going to work in -50/-60F weather conditions.
link below:
https://www.amazon.com/Schumacher-SE.../dp/B0000AXTUY
Old Feb 2, 2017 | 07:42 PM
dvldog458's Avatar
dvldog458
I have a Battery Tender 4 bank charger. I installed the battery terminal connectors that came with the unit so they are mounted via the side terminals and just hang out the front bumper for quick access. When I know the truck is gonna sit for a few days I'll plug in both connectors and let it charge.
Old Feb 3, 2017 | 12:59 PM
ithaca1230's Avatar
ithaca1230
I have one permanently wired in on the passenger side batt. I think it is a Schumache 1.5 amp. It is water resistant and have it tied in with the block heater. Seems to work good.
coreyallan01
Mar 4, 2015 07:43 PM
Special Ed
Dec 28, 2011 07:14 PM
mackl1
May 12, 2010 06:18 PM
Ford79
Feb 1, 2010 11:12 AM
EMS Guru
Electrical Systems/Wiring
Mar 22, 2005 09:55 PM
