Help transmission trouble
Old Jan 12, 2017 | 01:19 PM
jfarcmaster12's Avatar
jfarcmaster12
Ok I have a 1990 f-150 with a 302 engine along with an e4od tranny 4x4. My transmission is pretty usless right now, all gears except drive work, when I put it in drive and start to give it gas it is like it is limp mode. It takes the pedal almost to the floor to get it to move. But it will move just not that great in drive, I had replaced the computer a month ago because it went out, when I put the new one in the transmission went to s@!% . In the past month I have changed the trans fluid, tps, the nuetral saftey switch and cleaned all the plugs on the speed sensors. The one on the rear axle for abs, and the one on the transfer case. Im at my witts end I don't know if a rebuild is nessicary or not. If so what would it take to convert to a standard transmission. Or if its a simple problem I would like to know. Thank you!!
Old Jan 12, 2017 | 02:08 PM
88n94's Avatar
88n94
Does your transmission fluid smell or look burned. I realize you changed it in the last month.
Old Jan 12, 2017 | 02:16 PM
rla2005's Avatar
rla2005
That E4OD transmission is electronic controlled, have you checked for codes?
Your symptoms look like there is no power to the solenoid pack.
A 1990 model year F150 with a 5L engine could have an AOD or E4OD transmission. So assuming you do have the electronic controlled E4OD are you sure you got the correct PCM (computer)?
Old Jan 12, 2017 | 02:38 PM
jfarcmaster12
no didn't look or smell burnt, just sludge. I didn't see any burnt bands or parts in the pan.
Old Jan 12, 2017 | 02:40 PM
jfarcmaster12
I have no clue it bolted and plugged right in just depends on if the oreilys guy gave me the right one, how could I check?
Old Jan 12, 2017 | 02:50 PM
rla2005's Avatar
rla2005
The PCMs have the exact same pin count and location. It's the programming inside that makes one compatible with each engine/transmission combination.
Perhaps you still have the receipt with the part number they gave you? If not, you need to remove the computer (PCM) again to get the number off of it.
Old Jan 12, 2017 | 03:05 PM
jfarcmaster12
Ok looking at the recipt and orielys I got sold this one
MasterPro Electronics ECC154 - Engine Control Module | O'Reilly Auto Parts
look at it and see what you think but I think I got the wrong one.
Old Jan 12, 2017 | 03:21 PM
rla2005's Avatar
rla2005
Assuming your truck has an E4OD, it should have an OD On/Off button on the dash or the end of the shifter, then I believe the ECC154 is not correct for your truck.
If the above assumption is correct, E4OD transmission, I believe you need ECC1765
MasterPro Electronics ECC1765 - Engine Control Module | O'Reilly Auto Parts
Old Jan 12, 2017 | 05:05 PM
jfarcmaster12
Ok I do have a overdrive button on the dash, I will work on getting it exchanged and replaced and will report back.
Old Jan 12, 2017 | 05:55 PM
rla2005's Avatar
rla2005
I apologize for the disclaimers, but now I know for sure what transmission is in the truck. The mechanical/hydraulic AOD is more common behind a F150 w/5L engine in this vintage. Probably another reason why the parts jockey ordered the wrong PCM.
Old Jan 14, 2017 | 07:37 PM
jfarcmaster12
Ok got the new computer installed it fixed the problem with drive. When I started the relearning process everything when great except for:
Rough starting
spark knocking
and occasionally dieing
Could the engine just be out of time?
Old Jan 16, 2017 | 10:26 AM
rla2005's Avatar
rla2005
If the engine ran okay with the old computer then I would say your "new" computer may have other issues.
But I would suggest to check the base timing, SPOUT unplugged, to verify.
carsronnie86
Apr 22, 2016 09:26 PM
Benchwarmers6
24
Apr 15, 2016 03:45 PM
Tractorman1215
Sep 9, 2013 05:12 PM
body9599
1978 - 1996 Big Bronco
Jan 14, 2013 07:34 PM
CT
Jul 9, 2005 05:02 PM
