Help please!
Old Sep 9, 2013 | 04:40 PM
Tractorman1215's Avatar
Tractorman1215
Help please!
Okay before i start i know keep to the same thread but i reply on the old one and no one answers so i start new ones. Now down to business. As most of you know ive been tackling this transmission issue in my 1995 f150 5.8 e4od 4x4. I first started with MLPS changed it still same issue. Next Solenoid Pack still same issue. Then i changed transmissions it now has a e4od 4x4 with 62k and a upgraded torque converter still the same issue i did use the old solenoid pack out of the original e4od (not the new one) and the old transfer case. I checked fluid -full, check the sensor behind the speedo doesnt seem to be broken or damaged. I just changed my PCM, the issue got alittle better but its still present. I dont know what to look or do next. Any help is very much appreciated. Ps. I changed the tps and vss there are no codes and both seem to be fine according to eletrical test. Again any advice is appreciated.
Old Sep 9, 2013 | 05:02 PM
'89F2urd's Avatar
'89F2urd
i normally say, "maybe you should stick to your original thread"
but,
im feelin generous. the problem is that your transmission is automatic.
Old Sep 9, 2013 | 05:09 PM
Tractorman1215
but,
I know sorry im just annoyed with the truck and thanks i know next one will be a standard or maybe a c6. But anyway any ideas
'89F2urd's Avatar
'89F2urd
i kid i kid. . .
you need to find a donor eec out of a 5.8 e4od truck that you know works and swap it to see if your problem goes away. you've inherited the same symptoms (i have no idea what they are) with a different trans and setup, so its a good possibility that the eec is the culprit.
i see that you changed the pcm. . .what did you put in there?
Old Sep 9, 2013 | 05:12 PM
Tractorman1215
i kid i kid. . .
I know lol, i put a auto electronics reman pcm matched to my vin etc. And whats the eec
kxdan01
Aug 6, 2017 04:56 PM
jfarcmaster12
Jan 16, 2017 10:26 AM
BWD444
Dec 22, 2016 10:05 AM
xavier23
Jul 4, 2013 05:50 PM
oregon250
Jul 20, 2003 10:51 PM
