Battery Cables/terminals
Old Jan 8, 2017 | 05:38 PM
TXdoug's Avatar
TXdoug
I need to repair the ends of my battery cables. Looking at something like this.
https://www.amazon.com/Military-Spec...XT0H0Y11QVCP9C
I am trying to figure out the wire sizes for the crimp connectors. The drivers side measures (with insulation) about 10.4 and 12.4 mm, is that 3/0 and 4/0?
The biggest wire on the p side pos measures over 16mm, is that a 6/0?
I don't own a crimper for these sizes but I'll get one if I need to. Open for suggestions.
Old Jan 8, 2017 | 06:16 PM
DieselDenny's Avatar
DieselDenny
Custom Battery Cables F350 cables
Old Jan 8, 2017 | 06:29 PM
IDIoit's Avatar
IDIoit
I always make my own cables.
I use 00 gauge wire, the bigger the better, IMO.
also, I like upgrading to group 31's
overkill in your starting system is never a bad thing.
Old Jan 9, 2017 | 08:38 PM
TXdoug's Avatar
TXdoug
Originally Posted by DieselDenny
I can buy a whole set of crimpers for that price. just can't imagine that all that copper is bad.
Old Jan 10, 2017 | 02:44 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Mine was, Doug. Burned up alternator after alternator for a couple of years. All the wiring was corroded and green from the B+ cable coming off the back of the alternator to the entire positive battery harness. A brand new battery harness (all the red cables) is only about $85 from Rockauto. You will spend way more than that on crimpers and custom cable ends. I then replaced my B+ with high current 4 gauge wire. That was a lot trickier, as I had to come up with new splices/connections for my glow plug module and AIH relay.
Old Jan 10, 2017 | 07:39 PM
TXdoug's Avatar
TXdoug
Well Hell, at least I have run out of payments. I did buy pair of batteries yesterday. Everything fits a little tighter.
Mike is not often wrong on these deals so I guess I'll shop up some new cables while I'm living near my garage again.
cheers
doug
Old Jan 10, 2017 | 08:44 PM
Tugly's Avatar
Tugly
I bought a whole new positive wire harness, and I bought those mil spec battery terminal top post clamps (and covers) for the negative side. As for the lugs, I opted not to crimp - I bought Fastronix Eyelet Style Battery Terminals.
Old Jan 10, 2017 | 11:02 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Doug, It is under: electrical>starter cable. Price went up to $96 since I bought mine last year.
Old Jan 10, 2017 | 11:14 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I don't have one of those fancy hydraulic crimpers either, and I've always wanted one. But if you have a shop press, or even simply a bottle jack and a sturdy fixture, you can improvise crimps with block dies that are much cheaper to find, buy, or make... for an equivalent (if not greater) crimping and conforming force on the connection.
This is how I made a couple of battery cables just recently. I'm not a fan of the wire, but I already had it on hand, salvaged from someone's decommissioned $20K stereo install...
Old Jan 11, 2017 | 01:05 AM
retiredsparky's Avatar
retiredsparky
I am pretty sure that a good vice will give you enough pressure to make a good crimp using those dies. A little lube on the vice threads will help.
But, if you have to jusify a new hydraulic press, nuthin wrong with that!
Oh, and a little grease inside the lug probably would inhibit corrosion also.
Larry
Old Jan 11, 2017 | 02:32 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Ha, I wish that press were new. It was a 40 year old craigslist find, and that was 10 years ago. I simply painted it and put new hoses and hardware on it. The ram leaks like a sieve. It was a challenge keeping the hydraulic oil from pouring all over the connections like pancake syrup. Although, that might obviate the need for grease...
bismic
Mar 9, 2022 09:20 AM
nutinbutford
Jul 26, 2015 02:14 PM
Lex2002
13
Jun 26, 2013 01:21 PM
Bodaddio
Modular V10 (6.8l)
Feb 18, 2009 07:51 PM
catchtail
Oct 23, 2003 03:03 PM
