Level it the right way!
Old Feb 1, 2017 | 08:37 PM
  #106
kylant's Avatar
kylant
Originally Posted by Hackenbush
I installed mine today, pretty easy but it threw my tow in way out. Quick run to the front end shop and all is well...
that makes no sense at all. relocating the axle has nothing to do with toe.
Old Feb 1, 2017 | 08:47 PM
  #107
user 474747383's Avatar
user 474747383
Yea It did throw the steering wheel off to the left, just had to center the wheel and I set the toe at the same time.
Old Feb 1, 2017 | 09:07 PM
  #108
kylant's Avatar
kylant
readjusting steering wheel is normal. toe should not change. maybe it was out of spec prior
Old Feb 1, 2017 | 09:11 PM
  #109
user 474747383
Well it's dead on now and the left front tire is back where it should be. Was bugging the heck out of me.
Old Feb 2, 2017 | 03:37 PM
  #110
MagneticTiger's Avatar
MagneticTiger
Originally Posted by Pvincentt
I bought the kit from Stage 3 Motorsports
Where did you get the caster bushings?
Old Feb 2, 2017 | 04:43 PM
  #111
user 474747383
Amazon has them
Old Feb 3, 2017 | 08:48 AM
  #112
kylant's Avatar
kylant
i have yet to have the caster bushings installed. however, i cannot tell any difference in the way my truck handles or steers. it seems to drive the same as stock
Old Feb 3, 2017 | 09:04 AM
  #113
Wirelineman79's Avatar
Wirelineman79
Amazon has them
Which caster bushings on Amazon are the correct ones for our trucks? None of them say they are for a 2017.
Old Feb 3, 2017 | 09:26 AM
  #114
user 474747383
Moog 80154
Old Feb 3, 2017 | 09:27 AM
  #115
user 474747383
At least have it checked.
Old Feb 3, 2017 | 09:39 AM
  #116
Wirelineman79
Amazon has them
Moog 80154
Im assuming you mean Moog K80154? Thank you for letting us know.
Old Feb 3, 2017 | 09:44 AM
  #117
user 474747383
Opp's yea .sorry K
Old Feb 3, 2017 | 10:34 AM
  #118
347Flatty's Avatar
347Flatty
Moog 80154
They also might have them at the local auto parts shop. I picked some up at O'Reillys yesterday. The 80154 are fully adjustable from -2.5 to +2.5 and anywhere in between. The 80126 as mentioned before are not adjustable and are only 2.5 degrees.
Old Feb 3, 2017 | 05:30 PM
  #119
Pvincentt's Avatar
Pvincentt
I have yet to get mine in to check the camber also. It seems I need to get the fully adjustable bushings though. After driving my truck for a while now with the level...I do think the steering seems just a little bit off. Not bad but not as stable..like straight line tracking. I'm curious to see where its at. hmm... maybe if the local orielly's has the bushings maybe ill mess with that tomorrow
Old Feb 3, 2017 | 05:47 PM
  #120
347Flatty's Avatar
347Flatty
I know carli kits come with a 2 degree bushing so I might start there.
