I called readyift to get that part number for the 2017 it is correct per them. That Fox link does say 2016 on their shock listing but i used that just for shock model comparison.
i ordered and just finished installing the Readylift track bar bracket I ordered through Amazon, prime. It is the one listed up to ’16. I called Readylift prior to ordering to confirm, it is indeed the correct part number. I actually called them this am to confirm what I received was correct. The box from amazon had the correct part numbers, but the Readylift security tape had been cut, the box had been opened. The person I talked to told me how to confirm it was the right piece. It was. It is installed. I was able to bolt the track bar right up. Usually getting the track bar bolt back in is a two person job. Easy today. The axle looks pretty darn centered
i called Readylift this morning and asked them the correct part number to order. He told me as was posted earlier in this thread it is PN 67-2538 for the 2017. That better be correct when mine arrives.
What did he say to confirm ? Mine will be here tomorrow.
measure the center to center distance for the bolt holes where it attaches to the frame. he said it should be the same as factory. It was.
how did you install your caster shims? I tried to install mine today, but I could not get the factory shims out. I think I will have the alignment shop install them then align it on Friday
My truck only has 600 miles on it so they punched right out. But have the alignment shop do it, you need them any way. Mine needed 1 3/4 deg Camber on the left, and 1 1/2 deg Camber on the right to reach Spec's, Caster reached within Spec. And I only did a 1 1/2" lift.
Factory Cams only goes to 1 deg.. Set the tow and let it go...
I installed mine today, pretty easy but it threw my tow in way out. Quick run to the front end shop and all is well. Gotta say it towed a lot better like stock..
Do you mean it tows better now? Or before the level?
I have mine in the garage once it's not in the 20s outside I'm gonna install it. Seeing the wheel stick out on the driver's side bugs the heck out of me.
