Heating Help
Old Jan 7, 2017 | 11:24 AM
jonmammenga's Avatar
jonmammenga
Heating Help
I just restored my 1979 F150 4x4. It is AC and I also replaced the heater core when I restored the truck. I remember the heater used to pretty much bake me out of the truck years ago and this winter it seems to not keep up very well. The supply and return lines to the heater core are both hot. Is there a blend door or something that is not functioning correctly or a vacuum operated solenoid not operating correctly? Any help is appreciated.
Old Jan 7, 2017 | 12:56 PM
78 PEB's Avatar
78 PEB
New core.....I would bet that it is blend door related....or the way the heater core is sealed to the box.....the foam deteriorates over time......never owned a dent with AC so not much more help than that. When working correctly a dent heater will broil your toes LOL
Old Jan 7, 2017 | 01:20 PM
good to doo's Avatar
good to doo
On the back of the heater controls on the dash, there is a vacume unit with many vacume lines leading to it. These go bad.
Old Jan 7, 2017 | 08:13 PM
PapaBearYuma's Avatar
PapaBearYuma
Perhaps the squirrel cage fan is not blowing. Do you have airflow?
Old Jan 7, 2017 | 10:39 PM
meangreen92's Avatar
meangreen92
Did you go with a colder thermostat in the engine?
Old Jan 8, 2017 | 11:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by good to doo
On the back of the A/C heater control panel on the dash, there is a vacuum unit with many vacuum lines leading to it. These go bad.
D5TZ-19B888-A .. A/C Vacuum Controlled Selector Valve Assy (Motorcraft YH-285) / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 292 = 800-476-9653.
1973/79 F100/350 & 1978/79 Bronco with factory installed integral A/C or Hi/Lo Comfort Vent System.
Factory installed integral A/C is combined with the heater. The A/C controls are in the same panel as the heater controls.
All the vacuum hoses used with the blend door motors and the heater water valve connect to this valve that also has the "kicker switch" mounted on it for the A/C compressor.
Old Jan 8, 2017 | 06:01 PM
burnthelight88's Avatar
burnthelight88
As long as you have airflow it definitely sounds like you have a blend door issue. That being said, these aftermarket cores are usually cheaply made and sometimes bad out of the box.
GySgt0369
Dec 21, 2008 04:58 PM
greenterror
Oct 14, 2007 08:53 AM
Seguinswat
Mar 22, 2007 02:38 PM
pikiluvi
Apr 18, 2005 02:49 PM
jmule
1997 - 2003 F150
Dec 17, 2004 10:37 AM
