Sponsored by: Real Truck
1999 Super Duty heater problems
Old Dec 21, 2008 | 11:34 AM
GySgt0369's Avatar
GySgt0369
For a couple of years now my heater has only blown cold air, but this has not been a problem because I live in the Mojave Desert. The snowstorms we had this past week created all sorts of problems for me as you can imagine. I have checked the thermostat as well as the lines running to the heater core and cannot find any problems there. I have confirmed the fuse to the heater is still good. Other than that I am not sure what to check or what could be wrong. The AC works fine it is just the heater will not blow hot air. Any help would be appreciated!
Old Dec 21, 2008 | 03:29 PM
ReAX's Avatar
ReAX
I bet the blend door is jammed or you don't have vacuum getting to it. You're going to have to open the blower case and make sure the doors close. There is a door that flips between the AC condenser and the heater core, if it doesn't open up the heater core the heat doesn't make it to the ducts.
You should also feel both hoses going to the heater core, if one is hot and the other is not, coolant isn't flowing through the core.
Old Dec 21, 2008 | 03:53 PM
GySgt0369's Avatar
GySgt0369
I have checked to make sure that both lines are hot, but I will check that door to make sure it is working as well. On another forum I was told to change the vacuum switch located below the heater core and I will try that as well.
Old Dec 21, 2008 | 03:57 PM
ReAX's Avatar
ReAX
I think we are on the same page. The vacuum solenoid is what controls the doors in the blower case. There should be a couple of them.
Old Dec 21, 2008 | 04:58 PM
GySgt0369's Avatar
GySgt0369
Turns out the blend door was in the wrong position so for the time being I have heat until I can get another actuator. Thanks for the help in solving my problem!
rudedogii
1978 - 1996 Big Bronco
May 23, 2009 01:48 AM
fun_suv
S. California Chapter
Jan 7, 2009 01:44 PM
Beaus Truck
2004 - 2008 F150
Feb 10, 2007 11:16 AM
Mike W
52
Sep 15, 2004 04:57 PM
Menudo
Aug 11, 2004 02:06 PM
