I have a set that came with my truck Not going to install them. I've searched and while can find threads regarding them no real info as to worth? They do seem rare and only for sale add(old) priced them at $600? An
y interest out there for these?
I would say they are sort of rare but not worth $600 no way no how IMO. Maybe after you get your question answered you should put them on the FTE classified's..where things like this are suppose to be sold.
Oh ok then. I figure they are worth 50 bucks to a guy that does not have a set. I am not sure if you can simply remove the non pop out (fixed) glass and install the pop out ones.
I am pretty sure there is a window seal difference between the 2.
I have the seals but if that's all they are worth I'll just chuck'em..........
I purchased both windows and latches for $75 ($50 + $25 SH) on EBay, found out that the glass (Need to drill a hole in the glass) and inner seal are the same, the frame and outer seal are different so very easy conversion.
Oh ok then. I figure they are worth 50 bucks to a guy that does not have a set, and really needs a set.
I am not sure if you can simply remove stationary glass and install the movable type?
The part # of the seal seems to be the same. 29904?
29904 is the basic part number for both the stationary and moveable quarter windows, but that doesn't mean that these weather strips are the same.
In fact, they are not the same, scroll down to 29904
Notice in the pic the 302A12 quarter window hinge plastic retainers. These are the same as 1972/80 Pinto/Bobcat station wagon quarter windows and are available NOS
1972/74 Pinto/Bobcat & 1974 Super Cab are different than 1975/79 Super Cab & 1975/80 Pinto/Bobcat.
Oh boy...Do you not understand what "SEEMS TO BE" means? I did not say "it is for sure" or any other statement even near that. Thanks for the parts #'s, you can keep the to yourself.
