E4od solenoid pack connector
Old Jan 4, 2017 | 12:49 PM
7threeaz's Avatar
7threeaz
So I was getting hard shifts and a flashing OD light and today I went to check and clean all the connections. I pulled the plug off the solenoid pack on the pass side and cleaned it all out. Put a little dielectric grease and tried to plug it back in but wouldnt go all the way. Took a photo and looks like 2 of the pins are bent pretty good on the famle side that sits on the tranny.
So my question is does this come out as a complete assembly with the solenoid pack? Or is the plug seperate?
Old Jan 4, 2017 | 01:00 PM
7threeaz's Avatar
7threeaz
Just answered my own question. Guess searching works Oh well bout time for a fluid change anyway
Old Jan 6, 2019 | 05:09 PM
wizzy1998's Avatar
wizzy1998
Yeah. It comes out as a unit. There's a seal around the connector where it pushes into the trans housing. Make sure you dont overtorque the screws, or you can distort the pack assembly screw holes, which are right next door to the valve bores. Any distortion of those bores will affect the valve operation. Most recommend 98 in lb. On the hardware. Make sure you get the appropriate pack assembly, as they are different on 95 and later models as opposed to earlier models.
Old Jan 7, 2019 | 06:32 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
You should be able to bend them back in place with a pick.Might take a while but you'll get it.Might be easiest to just drop the pan and pull the pack and work on it out of the truck.
flyboyd8
Apr 18, 2023 06:50 PM
nick2064
Apr 4, 2017 12:31 PM
velcro7279
Sep 8, 2016 12:52 PM
CodyAustin
Sep 1, 2016 09:04 AM
javi2001
Sep 8, 2007 03:18 PM
