Stealing a 2017?
Old Jun 6, 2017 | 05:54 AM
  #91
troverman's Avatar
troverman
You can't disable the alarm by manually unlocking the door. If you do, there is a brief countdown timer during which you could "start" the engine to cancel the alarm; otherwise the alarm sounds. Likewise, there is no way to hot wire the engine to start even if the vehicle is manually unlocked.
Old Jun 6, 2017 | 07:45 AM
  #92
Tex68w's Avatar
Tex68w
This is no joke, South Texas tends to have the demographic of the types that want these trucks in a certain other country just south of the border for a certain type of industry.
In 2010 I had a brand new Ford, still had paper tags on it, stolen in Sugar Land. It was gone for over 48 hours by the time I had returned to find it had been stolen. Cameras at the border showed it going south into Mexico. Last year, in San Antonio, which seems to be ground zero for Super Duty theft, I had my 2016 KR broken into at the the JW Marriott in the Stone Oak area. Thank goodness I had my guns on my person at the time but they took everything else from the truck. My brother in laws father had his 2015 Platinum broken into along with all of his locked bed boxes not more than 1/2 mile from the same location where mine had been broken into only a few short weeks later. If you're going to be on the north side of San Antonio you can almost be guaranteed to have your truck broken into at a minimum if not entirely taken.
From what I understand, San Antonio has a ring that targets these trucks due to the ease of entering through the paddle style handle and because of their overwhelming popularity/demand in Mexico. The insurance adjuster told us that a few of the major insurance companies actually employ full time spies/investigators/recovery agents to live down in Mexico and look for these stolen trucks. There has to be a massive amount of loss in one style of vehicle to go to such extremes to attempt to recoup some of these units.
The best two options to combat this are to install the steel blocking plates behind the handles and/or replace the drivers side handle with rear drivers side handle that lacks the lock barrel/tumbler. Thieves typically punch out the lock to gain entry but in my case (since I had no lock on the drivers door) he went directly for the pry method and jacked the entire door panel up, insurance paid out nearly $4K just to reskin the door.
Old Jun 6, 2017 | 07:46 AM
  #93
k7lvo's Avatar
k7lvo
Yep. My 14 works the same way. BTDT...
Old Jun 6, 2017 | 07:52 AM
  #94
Kenv's Avatar
Kenv
Originally Posted by jm-bc
Perhaps it has already been fixed, shortly after getting my Job 2 truck (Feb 24 build), I used the key to unlock the door, opened it and promptly set off the alarm. I do not want to try it again at this late hour.
BTW, I am not following your solution.
In custom car circles it's basically called shaving the door....or in this case shaving the handle. You take the handle from the back door which does not have a key hole or the cylinder to unlock and you put it on the front door. You have to use your remote or keypad to get in(which is what I do anyway with a Platinum). I put a back handle I my 2011 after they punched my cylinder out and it worked fine. I'm just concerned about this new method I heard about yesterday. Just turning the whole piece behind the door handle and the alarm is disabled???
Old Jun 6, 2017 | 07:53 AM
  #95
troverman's Avatar
troverman
I'm curious how these guys are stealing these trucks and actually driving them away? Or are they going on a flatbed?
What I mean is that if you break in, fine, you're in...but the car doesn't start. And it cannot be hotwired. You need the correct transponder chip in the fob which is coded differently for every vehicle. The engine computer needs to match the fob transponder code. If not, the computer won't fire the injectors.
So how are these guys doing it?
Old Jun 6, 2017 | 07:56 AM
  #96
troverman's Avatar
troverman
Originally Posted by Kenv
...I'm just concerned about this new method I heard about yesterday. Just turning the whole piece behind the door handle and the alarm is disabled???
Not true. Using the key to unlock does not disable the alarm. The vehicle is aware the door was manually unlocked and starts a countdown timer - I think 30 seconds - giving a legitimate user the opportunity to "authenticate" by starting the vehicle.
It would potentially give someone very skilled enough time to open the door, open the hood, and disconnect the battery(s) to prevent the alarm from sounding. I don't believe these trucks are equipped with battery back-up sounders as some European cars are.
Old Jun 6, 2017 | 08:08 AM
  #97
Tex68w's Avatar
Tex68w
Originally Posted by F2502011
Last truck I had had the push button start. I hated it to start with but grew to love it. Was very nice to walk up to the vehicle with the fob, grab the handle and it unlocked. So I ordered my new truck with all available a la carte Lariat Ultimate components but without the Lariat Ultimate pkg because I wanted a key. I wanted a key because I'm concerned that the button or fob may fail and I wouldn't have a way to crank the vehicle. Plus I'm a runner and don't like running with a key so a lot of times with my truck before the last I would lock my key in the truck and use the keypad to get in. It was nearly impossible to do this with the keyless start.
False, you can leave the fob in the truck and just like previous generations, you push the last two buttons on the door at the same time to lock the truck. To regain entry, simply enter the door code and it'll unlock. Again, this works, but it is not recommended seeing how you are leaving the easy get away for a thief if the fob/key is in the truck.
Old Jun 6, 2017 | 04:26 PM
  #98
matrix311's Avatar
matrix311
I don't understand what his concern is either, Ken (see my post above). In my opinion, having the Ford door keypad is an awesome feature and one I would seriously miss for this very purpose of locking your keys in your vehicle while biking, running, etc.
On models with the Intelligent Key, the system senses the location of the key. If it is out of the vehicle, you can lock with the door button, the lock thumb pad on the handle, the fob itself, or the code pad. However, if the fob is inside the vehicle, the only way you can lock the vehicle is with the code pad. Once the code pad is used to lock the vehicle with the fob inside, the touch - sensitive handles are disabled, since the key would be in range. (Unless you use the second fob to unlock). Very clever on Ford's part, and no other vehicle at any price range offers this feature.
Well i just tested this theory. I put my fob in the truck, rolled the window down and locked the door using the keypad and it enabled my alarm. I crawled in through the open window and attempted to start the truck and it started right up. The minute I started it the alarm started going off. booo
Old Jun 6, 2017 | 05:35 PM
  #99
Rebelz's Avatar
Rebelz
Lmao... you should have recorded that test and posted the video. lol I dont think I could even get through my window. Not without a ladder.
Old Jun 6, 2017 | 05:45 PM
  #100
matrix311's Avatar
matrix311
Yep I used a ladder to get in. Was no easy task but I made it happen. I should have had my skinny son climb in and do it.
Old Jun 7, 2017 | 06:42 AM
  #101
troverman's Avatar
troverman
What part of the theory did you test? I never said the truck wouldn't start...I just said you would not be able to enter the truck without using the keypad or a second fob. I think most folks looking to secure their trucks would not leave the window down...
Old Jun 7, 2017 | 07:13 AM
  #102
bushpilot's Avatar
bushpilot
most thieves are lazy - theyll open the door to get in....after popping the glass...they don't smash the glass any more - it's too noisy and attn getting.
on my 2004 I disconnected the key/tumbler - and I put black tape over the hole (from the inside)....you could spin the tumbler in its housing all you wanted but it was disconnected from the lock rod.
I also created a fuel pump disconnect - used it when I was in high theft areas (mall & movie theater parking lots etc).
I was broken into 2x - once before I had any protection (via the door/tumbler) and once via the window (they grabbed the radio head unit the 1st time & my valentine one the 2nd time)...
I NEVER and I mean NEVER EVER leave anything in view, inside the truck - if I can't hide it I take it w/ me....I have 5% tint over the factory rear tint and 15% on the front doors....makes it hard to see in.
LiquidSteam
Aug 11, 2017 07:36 AM
Nipperdog
6.7L Power Stroke Diesel
Jun 22, 2017 09:40 PM
RM2738
Apr 28, 2011 03:56 AM
FTE Trigger
North Carolina Chapter
Mar 26, 2009 05:33 AM
alabamabuddog
Tennessee Chapter
May 28, 2006 11:38 AM
