steering column too long
Old May 2, 2005 | 08:08 PM
mrwillie66's Avatar
mrwillie66
I added power steering and a tilt column to my 66 but the column seems too long. I saw another p.s. box on ebay that looked quite a bit shorter. I believe it was a bendix. Am I mistaken? I thought about shortening the column about 4 inches if all else fails.
Rob
Old May 2, 2005 | 08:55 PM
stevef100s's Avatar
stevef100s
The steering column on power steering trucks IS shorter. I always use the column from the truck that donates the box.
Old May 2, 2005 | 09:45 PM
daveengelson's Avatar
daveengelson
The Bendix box does not require any column swap. The box is same size. length wise, as the manual steering box. Offered limited period of years and hard to find anyone who rebuilds them. The Ford and Saginaw power steering box's are longer therefore require either shortening column, or later model column. i intend to take the mounting bracket off the original and mount on the later model column, therefore not require spacers. May need to pay attention to the shifting tube and steering shaft if considering shorting column. Good luck
dave
Old May 3, 2005 | 04:49 AM
jowilker's Avatar
jowilker
Rob, The Ford gear by Saginaw from the 73-79 series is longer on top than the Bendix, but the column is shorter from the same series. A matched set if you will. The total measurement is the same for both your old and the new.
I would like to shorten mine a couple more inches, I like my arms more extended when driving.
John
Old May 3, 2005 | 06:04 AM
banjopicker66's Avatar
banjopicker66
Check out my gallery for pictures on the differences.
Old May 3, 2005 | 06:55 AM
Daplumma's Avatar
Daplumma
I just installed a bendex system in my 65 last weekend(thanx again Banjo).The bendex is less than an inch longer than the manual one.This can be made up by moving the housing toward the driver by loosening the mounts under the column and at the firewall.Rebuilt boxes are available at NAPA and autozone with a limited lifetime warranty.I installed a trans cooler on mine as recommended by a few people here.What a difference P/S makes.
Old May 4, 2005 | 07:44 PM
jcdtjaj's Avatar
jcdtjaj
Hey guys,
I wanna to do the same to my 65 six, from reading this post all I need is the box from a 73 - 79 along with the steering collum??
Old May 5, 2005 | 09:05 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
jcdtjaj
You need (ps) pump and brackets of same engine as yours, also a (ps)
cooler and it would not hurt to install a filter and new hoses.
Last edited by Pro-Street/StateTK; May 5, 2005 at 09:12 AM. Reason: Bad day with spelling
Old May 5, 2005 | 03:57 PM
jcdtjaj's Avatar
jcdtjaj
Why would I need a cooler?? I don't think that I've ever seen one on a car or truck.
Old May 6, 2005 | 08:06 AM
Pro-Street/StateTK
The cooler keeps the fluid cool and prolongs hose live! Lots of cars and trucks
came from the factory with them, they look like a steel hose that zig zags on
the low pressure return line.
Old May 6, 2005 | 03:29 PM
uba40's Avatar
uba40
66 Power Steering............
Hi Guys!!!
I have been wanting to do the power steering changeover for a long time. So!!!
1. The power steering box 69-78 bolts straight in, right??
2. If I use the steering column stalk from the donor truck the steering wheel is in the same position, correct??
3. If the above is all correct......... this is a slick changeover!!! I already have disc brakes, this would complete one of the higher priority items on the list for my 66....
Thanks for the thread which allowed me to hopefully confirm all of this.
Open to all comments, there is nothing worse than getting into a project and then having someone say "Oh!!, I forgot to tellya!!!!!!!!!" That's where I don't wanna be on a Sunday afternoon at 5:01 pm
Thanks a bunch folks
uba40
Old May 6, 2005 | 03:34 PM
uba40's Avatar
uba40
Talking
Uh-oh,
One more thing................
Is it possible I can get tilt, with column shift, AND no key on the column????
IF, I can do that, will my steering wheel still be roughly in the same position??
Thanks folks, not trying to be a pain in the butt, however, there is no need to reinvent the wheel if some of you have already been through this and I might be able to use your knowledge.
Thanks again, a bunch,
uba40
Old May 6, 2005 | 05:06 PM
Daplumma's Avatar
Daplumma
You could also get n old bendex system from a 65-67(I think) and it is a direct bolt up.No need to change the colmn.Make sure ya get the brackets and puleys you will need.Recommend you install a cooler.The bendex is not as durable as the newer systems,guess it depends on how much you use the truck.
Joe
Old May 7, 2005 | 06:22 AM
jowilker's Avatar
jowilker
Originally Posted by uba40
Uh-oh, One more thing................Is it possible I can get tilt, with column shift, AND no key on the column???? IF, I can do that, will my steering wheel still be roughly in the same position??
uba40
uba, I got your note, and since you have ask the question here, I'll reply here. I'll have to confess that I can never remember the first year the Ford/Saganaw gear was used, it is in all 73-79 years. The same gear was used beyond those years but the gear was moved in front of the axle so the control gear on top of has a left hand thread worm gear.
The donor gear and column for the slicks can be found from the 73-79 year models of the F100, 150, 250, as well as Bronco. The tilts were found in the 78-79 year models of the F & Bronco. I also have one from a van but you have to cut 6 1/2" out of the length. No locks on the columns.
hope this helps a little
John
Old May 7, 2005 | 01:16 PM
stevef100s's Avatar
stevef100s
The newer columns are just a little different. The wiring and plug connections aren't the same, and neither is the bracket that fastens to the under side of the dash. It's pretty easy to figure out how to rewire if you have the color code, and the bracket can be removed from the 65-66 column by drilling out the spot welds. Then simply position the bracket on the newer column, and tack weld in place.
quitcrab
Mar 19, 2017 02:57 PM
duke_boy
Nov 12, 2015 11:37 AM
PapaMatt
43
Jun 6, 2015 05:45 PM
astembridge
21
Jun 17, 2013 10:02 PM
THartman
Jul 28, 2012 07:01 AM
